I recently had 3 guages installed on the A pillar. Still getting used to them and had a question on the Pyrometer. On startup, the temperature is 200. It would seem to me that if it was picking up ambient temp. it would be 100 at max. during a summer day. Just curious as to what you guys notice when you start your trucks for the first time of the day.
It's cal'd to work in a certain temp range. Lowest is probably set to 200 since
it's useless to read ambient.
Nut
Too cold here to read ambient right now. Mine will work it's way up to 200 within a minute of starting the engine. I suppose if you parked in the sun, in southern New Mexico on the pavement with no wind it's going to be hot enough for the needle to move a litte before you start the engine.
