Engine noise just before start-up
Old Jun 8, 2007 | 09:31 AM
2005 Ford's Avatar
2005 Ford
Hey guys, have another question. On the first start-up of the day, every now and again I hear a sound. It occurs after the engine has stopped cranking and before it roars to life( yes its a split second sound). Not sure if its a problem or if anyone else has noticed this on their 6.0. It not cold out (54 deg) and i just had the oil changed ( sound occured once before and oil change and once after) Truck has about 60,400 miles. The sound is hard to explain, its sort of sounds like a turbo fart ( like when your hard on the throttle under load and you let off suddenly that whoomp sound) Thanks for the help.
Old Oct 8, 2007 | 10:03 PM
SpeedJunky's Avatar
SpeedJunky
I've noticed the same noise as well. It comes from the passenger side area, right?
Old Oct 8, 2007 | 11:16 PM
msgtg's Avatar
msgtg
Nope...that's a new one on me. Mine has 54K right now.
Joe
Old Oct 9, 2007 | 05:21 PM
dchamberlain's Avatar
dchamberlain
Does it only do it when it starts? You might try turning the key on and waiting 30 seconds or so. Mine does what I think is an ABS pump test sometime in there, sometimes before I start, sometimes right after. The sound it makes could be described as a "fart."
F350FordToy
6.2L V8
73
Oct 17, 2023 09:10 AM
Ken Wolkens
2009 - 2014 F150
Dec 12, 2015 01:28 PM
blueline970
Jun 5, 2015 07:24 PM
r___r
Dec 2, 2013 12:23 AM
mswpj
2004 - 2008 F150
Sep 20, 2008 09:15 AM
