Going up maybe??
Old Feb 1, 2006 | 08:14 AM
02ohioex's Avatar
02ohioex
Going up maybe??
Since I am a fairly new Ex owner, anyone want to chime in on options on lifting mildly?? I just dont know whats out there??...
Old Feb 1, 2006 | 12:12 PM
XMonster's Avatar
XMonster
To lift or not
I've had my x for 4 years and once the snow tires come off I'm lifting it 6". I'm going to a local place for the lift work (Les Schwab) they do good work. I'm not really big on the huge truck look. In fact the 6" lift was something I had to convince myself on. The guys at Les Schwab said most Ex owners who get a 4" lift wish they would have gotten the 6. So I'm going with the 6. Good brands I've heard of are Donahoe. I'm using a Rev Tech lift with high performance shocks. I called a Donahoe distributor and they said the RevTech is just as good if you get some good shocks and its half the price. Mine should be lifted and rolling by march.
Old Feb 1, 2006 | 01:31 PM
02ohioex's Avatar
02ohioex
how much do you think you are spending?? cost is a factor with me!!
Old Feb 1, 2006 | 01:39 PM
XMonster's Avatar
XMonster
Lift - approx $1,150
Shocks - $250
Tires - $1,200
Wheels - $1,200
This is if I choose to go with 17's instead of the 16's I currently have.
Helwig Sway Bar - $250
Like I said, its been four years. I've modified my X in alot of other areas so this is just the next one in a long series. Superchip, 4" Exhuast, Gauges, Nav System, Video System, Airbags, Tranny cooler, Audio, Grill, K&N filter, etc... This is a tough one because of the dollars all in one shot but i have to replace the tires so I'm doing it now rather than in the next 30,000 miles.
Old Feb 1, 2006 | 01:49 PM
02ohioex's Avatar
02ohioex
not too bad! i am still swaying back and forth on it! well see....my first priorities anre exhaust and air filter, then billet grill and so on.....
Old Feb 1, 2006 | 01:50 PM
XMonster's Avatar
XMonster
Thats whats great about the excursion - lots of things to keep you busy and spend money on. Good luck.
Old Feb 1, 2006 | 01:53 PM
02ohioex's Avatar
02ohioex
Thanks X...I will keep ya posted, by the way did you just swap filters? or did you get the whole kit form K&N...I was thinking about buying a K&N universal application filter and removing the whole airbox completely....
Old Feb 1, 2006 | 03:31 PM
XMonster's Avatar
XMonster
I just got the filter. I wasn't going to go any more in depth with that until I replaced the intake etc...
Old Feb 1, 2006 | 03:38 PM
turboale's Avatar
turboale
Personally,
The only bennifit of a cold air intake is to block out the engine's hot air. I am going to start out with the Kwik intake mod which is cheaper than a K&N alone. Then do the exhaust/programmer and then later get a cold air intake last. You get the added flow and better sounds from the kwik intake mod, just not quite as efficient b/c there is no baffling to block the hot air produced by the engine.
For more info on the Kwik Intake Mod: Click Here!
Old Feb 1, 2006 | 03:45 PM
XMonster's Avatar
XMonster
That filter is huge!!!!
Old Feb 1, 2006 | 06:35 PM
02ohioex's Avatar
02ohioex
i might have to try that filter.....i wonder if napa is still open!!!!
Old Feb 3, 2006 | 12:27 PM
02ohioex's Avatar
02ohioex
has anyone tried that filter on a V10?? I bought the filter but we have a MAF and I dont know how it could work???
Old Feb 3, 2006 | 02:44 PM
hink10's Avatar
hink10
That's a great filter, I use one. You can get them at http://www.fleetfilter.com . Less than $20, but shipping is kind of high. Most people stock up on fuel, oil and air filters when they order, shipping is about the same.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
