1967 Cab swap
Old Oct 12, 2005 | 07:35 PM
wrecker1975's Avatar
wrecker1975
1967 Cab swap
I have just accquired a 1967 F-350 with a Holmes 440 wrecker mounted on the back. It has a 390 V8 with a 4 speed. The truck runs great and the wrecker unit is in good shape too. The problem is that the cab and front end sheet metal is very badly rusted. I cannot seem to find any decent used cabs for the '67 to '72 F trucks in my area. I however found a very nice cab off of a '78 F-150 and a mint doghouse and doors off of a '79 Bronco. I was told by a man at the junkyard that the '67-'72 F trucks are basically the same design as the '73-'79 F trucks and that the cab and doghouse from a '73-'79 will bolt perfectly onto a '67-'72 frame. Is there anyone here who knows if this is true or who may have done this swap? If the swap is possible are there a lot of modifications to be done?? Thank You.
Old Oct 12, 2005 | 08:31 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 12, 2005 | 09:40 PM
fabmandelux's Avatar
fabmandelux
Thumbs up
All ford f-100 thru f-350 from 67 to 79 all share the same cab mounting locations, the only differance are the bed mount locations. Isn't FORD great!! How wierd is this, take one mid 60"s bronco frame, shorten 14", MID 60's MUSTANG BODY WILL BOLT ON !!!! I've done 2 of them for customers. FABMANDELUX
Old Oct 13, 2005 | 05:36 AM
jowilker's Avatar
jowilker
wrecker1975 Welcome to FTE The best truck show on the net
Actually 65-79 cabs are bolt up exchange. You can cut a floor out of a 79, snip the added 4" off the back and weld it into a 65.
The yard owner was shooting straight with you. You possiabily could have a 390 but more likely it is a 360. All 352s & 360s become 390s on sale day because you can't visually tell any difference in them.
John
Old Oct 14, 2005 | 05:27 PM
71 Sport Custom's Avatar
71 Sport Custom
I swapped an F150 body onto an f350. The rear cab mounts on one were outside of the frame on brackets and on a crossmember on the other. I can't recall which is which. I think the dually used the outboard mounts. It wasn't a problem as the crossmember was there and drilled for the other mounts. Both trucks used were 74's. You should be able to look underneath to tell. I see you name is wrecker 1975, do you have another wrecker?
bmwcarl
Oct 31, 2023 01:26 PM
1985 Bronco
Mar 3, 2017 02:07 PM
tiredone
Aug 12, 2006 04:17 PM
6677ebman
Aug 13, 2003 11:14 PM
FTE Ken
Jul 9, 2001 10:01 PM
