heddman hedders
Old Feb 3, 2006 | 06:14 PM
AnOldDog's Avatar
AnOldDog
I think you guys will be quite pleased with the ceramic coated headers. What we are talking about is glass and it has a much higher temp tolerance than even powder coating. Should you melt the glass, it sort of anneals and forms back together. My neighbor has had a ceramic forge for over 10 years and it has never had issues. The only problem would be if one were to bang it with something and break the glass.
Be gentle and it may outlast the engine.
Old Feb 3, 2006 | 07:18 PM
jor's Avatar
jor
I have a leek on the driver side. What is the best way to get them to seal.
I always have leak issues with headers. Last time I used paper gaskets and a thin line of high temp RTV and it did the trick (for now).
jor
Old Feb 3, 2006 | 07:38 PM
ceetwarrior's Avatar
ceetwarrior
Jor, that's cause you are using the wrong port size gaskets. I had all those problems too until I figured out to get the same brand gaskets as the headers. Not a problem since, Check this out:
Old Feb 3, 2006 | 08:17 PM
Randyb12's Avatar
Randyb12
hedman statethat the paint is for rust prevention during storage and shipping only. It should be removed and repainted with high temp paint before use. I used Byson (not sure of the spelling) gaskets. Tfhey are approx. 3/16" thick and haven't leaked yet. They are used alot when standard gaskets keep leaking.
Old Feb 3, 2006 | 08:29 PM
rusty70f100's Avatar
rusty70f100
Heh, I've got some gaskets that look like that bottom one! LOL
Old Feb 3, 2006 | 10:27 PM
73F100*8Mile's Avatar
73F100*8Mile
ya i think the $300 elites w/ matching heddman gaskets are the way to go...i don't want any lip from headers b/c i've already gone through 3 sets of manifold gaskets after having my manifolds planed! soooo annoying but as far as the headers getting me around 30-40 more horses...they can leak all they want!
Old Feb 4, 2006 | 10:44 AM
fordeverpower's Avatar
fordeverpower
I like the summit brand copper gaskets, which appear to be S.C.E gaskets. They were $28 but a couple of cheap sets will add up too. My problem is with the collector, ball and socket style, anyways my bolts always come loose, like 20 miles of driving. The loctite hasn't helped much but i have extended my mileage range before retightening.
Old Feb 4, 2006 | 12:58 PM
ceetwarrior
Loctite won't do anything on hot headers dude! Try those 'bent' or 'squished' nuts that you have to impact on there. They won't come loose then. For added, do some lock washers too.
I tried the copper header gaskets from Summit, I found the ports to be too big. They would be great if they had smaller ports. The best I've found for Hedman headers is the headman header gaskets, as pictured above. Period.
77custom408
21
Sep 11, 2008 10:20 PM
Terran
Jan 24, 2006 12:34 AM
maximumhorsepower
13
Jan 2, 2004 06:24 PM
tx83bronco
Exhaust Systems
Oct 25, 2001 03:40 PM
mt66ford
Mar 15, 2001 11:01 PM
