Computer Chips & Tuners
Global line pressure???
Old Jan 31, 2006 | 05:05 PM
LxMan1's Avatar
LxMan1
I have a Predator for my 01 F150. There is a 0-50 adjustment for the Global line pressure for the tranny. It was set at 10 and I changed it to 20 but really didn't notice any difference. What exactly is it changing and how will it effect the tranny? Is it actually putting more pressure to the valvebody?
Also, are there any programs in the works to adjust part throttle shift points? My 1-2 shift is way to soon for me when taking off normal from a stop. It shifts before I ever get out of a corner to accelerate. Usually between 10 and 15 mph.
Thanks,
Jimmy
Old Feb 1, 2006 | 07:27 AM
MotorHaven Guy's Avatar
MotorHaven Guy
Its changing PSI of the line pressure through the value body which gives a firmer shift. It doesn't impact when the shift happens. The more throttle you give the firmer shift. I can't tell you what's in the works, only Diablo can answer that and they've gotten tight-lipped about future products and changes due to the competitive nature of the market.
Old Feb 1, 2006 | 03:41 PM
LxMan1's Avatar
LxMan1
OK, Thanks. I'll crank it to 50 and see what happens.
Jimmy
Old Feb 1, 2006 | 03:48 PM
MotorHaven Guy
That's pretty high. I recommend taking it up 5 points at a time to see where you like it.
Old Feb 2, 2006 | 06:30 PM
LxMan1's Avatar
LxMan1
I took it to 50, it firmed up a little more, not much difference though. I have the firmness set all of the way up on all gears, part throttle and WOT. I also have the torque modulation turned off.
LARIAT 85
'80-'86 HOWTO's
33
Apr 24, 2026 09:07 AM
thebigtruck
Feb 20, 2022 01:09 PM
wstone
Apr 11, 2017 08:56 PM
cuazman
May 21, 2016 06:29 PM
wantahertzdonut
Apr 15, 2015 01:44 AM
