headliner
Old Jan 29, 2006 | 11:00 PM
JerichoM1070's Avatar
JerichoM1070
headliner
Does anyone know if there is any difference between regular cab headliners from 87-91 and 92-96?
Thanks.
Old Jan 31, 2006 | 11:32 AM
JerichoM1070
Some one has to know.
Old Feb 5, 2006 | 07:36 PM
skrappy's Avatar
skrappy
no theres not. if youre looking for a good new headliner replacement www.acmetruckparts.com
Old Feb 5, 2006 | 08:12 PM
JerichoM1070
Thanks skrappy. My next question is what will it take to put a headliner into a truck that never came with one?
Old Feb 5, 2006 | 08:17 PM
skrappy's Avatar
skrappy
if you buy an aftermarket headliner it should come with everything you need..if youre getting one from the junkyard then ul need some things...youll need to attach it somehow since your truck probably doesnt have the trim pieces around that hold it up on the xlts...if uv done any work with fiberglass before you can make pieces fairly easily, otherwise i'd do it with some good adhesive, or if you want use stainless self tapping screws or small bolts to make it look rugged
Old Feb 7, 2006 | 08:11 PM
88F-150pimp's Avatar
88F-150pimp
I'd get some trim pieces from the junkyard, and then you can usually find some upholsterer that works out of a trailer that can install a headliner, headliner fabric/foam included, for $50. I was impressed with mine, just make sure they use some glue that won't melt in the sun.
1tonner
75
Mar 3, 2024 07:27 PM
Phil66Ranchero
Jan 3, 2007 07:08 AM
buzzard
Nov 7, 2002 09:37 PM
saanders
1978 - 1996 Big Bronco
Aug 31, 2002 06:59 PM
fordtrucksforever
Aug 17, 2002 09:44 PM
