tonner, there are several locations here on the site to get a pdf emailed to you. with that you can get a template made at places like Kinkos ( where there is a 3 ft printer)
I'm travelling or would send it to you. Search this site. If no luck I'll try to help you further.
all of the PDF's I have come across here on the site are not to scale and just show a drawing with minimal measurements that leave many of the curves and stuff out . I'd love to find a true pattern drawn to scale with all measurements myself .
I may have one still, I'll look a little later. My original drawing/trace template was given to Broomfield who then made them into PDF's
I remember seeing a copy in my garage when I moved here 3 1/2 years ago. I'll double check If I have one I'll let you guy's know.
txstang I can't send the pdf in this forum -- its to large. personal message (pm)me your email address and I'll send the pdf to you by email. Then you can have it copied on your printer or print it to scale on a 3' printer at a copy center
Scott
Reason: correct members name
I have a to scale PDF that prints on paper 36X66 that was scaled up with AutoCAD to verify the dimensions, printed and verified on paper. Shoot me a PM with your email addy and Ill send you a copy.
Scott
Scott, do you think I could get the PDF as well? Is it for the 2 piece or the 4 piece? Thanks, Cory
Anyone else want a copy while Im emailing a bunch out?
If I sent you a copy and need help with the printing part, email me back. I only troll thru the FTE forums maybe once a week, so I may miss your questions.
Robert, you want a full size copy? The big issue is people were sending this around to be printed on 8.5"x11" and they screwed with the scale of it. I had to fix that with AutoCAD (easiest way) and verify it against the dimensions on the first copy I had. I think IM right around 1/16" or less, so it should be close enough.
Corey, I would like to have a copy. I'm assuming its a 4 piece pattern.
I have access to a 48" printer at the University but it looks like it will print on a 36" so I have one at UPS down he road. Sounds great.
Thank you sir, here is my addy
themaskedr1der at ya hoo dot com
Please put your name on the email somewhere so I'll who it is. I don't open anything these days if I don' know where its coming from...
Thanks again Corey.............
Several years ago I made the original trace from a perfect four piece I picked up. I'm not computer savy enough to do it in a PDF form. I made 10 copies of the original trace and was selling these at the time. Some people complained about the shipping price. (I had to purchase the tube and pay for shipping)
So Broomfield contacted me about the patterns and he then put them on PDF form. That's how they wound up here.
I don't need a copy, I think I still have the original.
