Hi there,Electrical Problems
Old Jan 29, 2006 | 09:56 PM
mono570's Avatar
mono570
Trailering
Electrical Problems
Hi there,
Lately, I'm having compounded problems with the electrical system on my truck and I can't say if it's all connected! "Door Ajar" light stays illuminated on the dash but I know from previous posts that this may be a faulty door switch that needs to be replaced. Next, the Dome light inside the truck stays illuminated for a longer period of time than normal: takes maybe 10 minutes to switch off even when I'm driving. Is this related to the door switch?
The latest problem is the anti theft alarm blows off the horn for hours on end...The battery that runs thie horn is almost out of power because the anti-theft horn sounds like a sick fog-horn.
Anybody else experienced this problem? Is there a simple fix or do I need brain-surgeon?
All input greatly appreciated...
2000 F-250 Superduty Diesel
Old Jan 29, 2006 | 10:51 PM
BadFord99's Avatar
BadFord99
I had pretty much the same interior light issue with my 99. Only thing I did was clean the switches and replaced the accessory delay relay.
Old Jan 30, 2006 | 02:43 AM
99F-250lova's Avatar
99F-250lova
My door ajar light is always lit up. I am going to spray some WD-40 on the switches to see if it goes away. I am also having a problem with my interior lights. The only problem is that I can't get mine to come on when I open the doors. They do work if I turn them on manually but they don't automatically turn on. Anyone having a problem with this?? Also, I have checked all the fuses and they are all good so I don't know what the problem is.
Old Jan 30, 2006 | 03:34 AM
cangim's Avatar
cangim
All the above problems are related to the door switches, anti theft going nuts because it thinks the door is being opened. Light wont turn on with door because it thinks the door has been left open, however, it should turn back on when you turn the key on. Is the door ajar light on when you turn the key on?
Old Jan 30, 2006 | 05:32 AM
99F-250lova
Yea, right when I turn the key it comes on and stays on. Interior lights never come on unless I manually turn them on.??????
Okief250
Apr 14, 2013 03:51 PM
cardc26
Sep 18, 2012 05:04 PM
teamlx88
Aug 3, 2012 08:53 AM
jackknife
1997 - 2003 F150
Jul 22, 2004 02:06 PM
Richard4447
1983 - 2012 Ranger & B-Series
Nov 10, 2003 04:22 PM
