loose tie rod
Old Jul 23, 2001 | 08:49 PM
oldyellor's Avatar
oldyellor
loose tie rod
i have a 1975 F-100 with a loose tie rod on the left (i can wiggle the rod about a quarter turn) , the right tire was cupping and i have practically no return of steering along with a popping sound when i turn slow.can the loose tie rod be causing all this or is there something else wrong too.any help would be appreciated, thanks.
Old Jul 23, 2001 | 09:21 PM
BigBrownTruck's Avatar
BigBrownTruck
loose tie rod
Old Jul 23, 2001 | 10:09 PM
lastchance's Avatar
lastchance
loose tie rod
The tie rod should not have any play in it at all, side to side or up and down. If you can only swivel it a little on the joint it is OK yet. As far as the popping and lack of steering return (assuming it is a 2 wheel drive) I would suspect the kingpins are probably about froze up. I had the same problem with a '73 F150 I had. I'd have to crank the steering wheel back straight after going around a turn just as hard as it was to turn into the turn on the way in. I had tried pulling the caps, soaking them with penetrating oil to clean them up, then greasing the heck out of them, but it wasn't ever right until I replaced the kingpins. Made it drive like a new truck.
glovemeister
18
Sep 24, 2013 09:00 PM
zach1877
Aug 1, 2006 02:35 AM
Kongslibakken
Jun 16, 2005 10:15 PM
Stiers
Aerostar
Feb 18, 2002 10:55 PM
