Fuel treatment
Old Jan 29, 2006 | 07:26 AM
trucker41's Avatar
trucker41
Fuel treatment
My boss took his truck (2006 F350 6.0) to the dealer because it was smoking They told him number 4 injector was weak, and we should start running fuel treatment( to boost the cetan) in our trucks because we needed to run premium diesle. My truck is a 2003 F350 6.0. Just was wondering what you all thought about this. He also recommended Cetan booster and power booster made by Ford ( Imagin that) I would think you couold buy something cheaper that would do the exact same thing.
Old Jan 29, 2006 | 07:51 AM
busdriver47's Avatar
busdriver47
I use power service diesel kleen get it at wally-world less than $13.00 for 96 oz.
Old Jan 29, 2006 | 09:28 AM
saftman's Avatar
saftman
Stanadyne or Power Service.
Old Jan 29, 2006 | 09:33 AM
kw5413's Avatar
kw5413
Please do yourself a favor a back up one notch to the general 6.0 forum and do a "fuel additive" search...lots and lots of info & discussion.
Old Jan 29, 2006 | 11:01 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Check out the following thread I started and many contributed to...
Should answer all your questions.
https://www.ford-trucks.com/forums/s...63#post3272563
Old Jan 29, 2006 | 06:22 PM
trucker41's Avatar
trucker41
Thanks all good reading Beachbumcook
Old Jan 29, 2006 | 06:43 PM
Dogs of war's Avatar
Dogs of war
I was at Wally World today and was checking the same stuff out. Which one do you use? The white or gray bottle and why?
Old Jan 29, 2006 | 10:26 PM
King of the Road 04's Avatar
King of the Road 04
depends winter or summer.............hot or cold.......................white is for cold, grey if for summer...............if where ur at doesnt get below 30 or so, stay with the grey ull be fine......but none the less use one of them................its very important
Old Jan 30, 2006 | 06:58 PM
Dogs of war
Thanks alot.
Old Jan 31, 2006 | 07:30 AM
What Man's Avatar
What Man
Fuel treatment
I would advise teatment of fuel. Diesel just isn't the same as it use to be. The sulfur levels are much lower, there for deceasing the lubracation of the fuel. If you know any old timers that ran diesel trucks they used to call it diesel oil. I believe next year 07 they will be taken even more sulfur out of the fuel. Treating the fuel helps replace some of these lubracates as well as other things. This will keep the pump and injectors lubed.
