chips and tuners check engine light
Old Aug 16, 2004 | 12:52 PM
mtgrzlyman's Avatar
mtgrzlyman
do these activate the check engine light?
Old Aug 16, 2004 | 03:27 PM
ltfox's Avatar
ltfox
They should'nt.
Old Aug 16, 2004 | 05:53 PM
wlihntr's Avatar
wlihntr
if your chip causes you turbo to make over 24 psi of boost it will set the ses light for as long as you are over 24 psi. some companies make a boost control valve to correct the problem. as well as setting of the light it will defuel the engine so you will not have full power over 24 pounds of boost
www.dieselinnovations.com look under "misc."
madman666
Dec 11, 2001 09:06 PM
gblakeney
Dec 10, 2001 10:32 PM
rsbeadle
Mar 22, 2001 10:55 AM
billyb
Feb 26, 2001 07:28 PM
custodian
1997 - 2003 F150
Jan 15, 2001 05:52 PM
