390 Heads
Old Jul 26, 2001 | 04:29 PM
Honored1's Avatar
Honored1
390 Heads
Hey,
This is my first time on the board. I have to confess to having owned Mopars most of my life. My father has a Ford though and its turning my hair gray. He has a 1972 Ford 250 Camper Special. He got a rebuilt 390 from a fairly reputable shop for it about 2 years ago. He has had nothing but trouble with it since. The story is long and I will spare you the details, but suffice it to say that he finally broke down and called me. When he said he had 180 lbs of compression in each cylinder the light began to come on. According to my calculations, that means he has at least 10.2 or 10.3 to 1 compression. He has been running pump fuel. The moral of this story is that he seems to have the high compression 390 heads. My books say they went as high as 10.5 to 1. High compression may be great for a racing engine, but not for a truck used to pull a trailer. So, after all of that here is the question. First, where are the casting numbers on a 390 head? Second, are the high compression heads worth anything to someone else?
Thanks
Old Jul 26, 2001 | 04:42 PM
PetesPonies's Avatar
PetesPonies
390 Heads
Before you get all exicted over the heads, lets see what they are. The casting number is on the exhaust side of the head, near where the manifold bolts are. It's probably all rusted as the paint burns away in the area. Clean ir up and see what it says. There will be a letter then a number folowed by two more letters. This will be followed by 6049 and another letter.
Pete's Ponies
Mustang RUSToration & Performance
Old Jul 26, 2001 | 07:26 PM
Honored1's Avatar
Honored1
390 Heads
I just spoke with him and the casting numbers are: C8AE-6049-H So, I am told that these are 1968 heads from a galaxie. What does the H mean?
Old Jul 26, 2001 | 07:41 PM
Honored1's Avatar
Honored1
390 Heads
By the way, the intake valves measure somewhere near 2 inches in diameter
Old Jul 26, 2001 | 08:05 PM
FE427TP's Avatar
FE427TP
390 Heads
C8AE-H is a standard emmisions era head, just because he got high cranking pressure doesn't mean he has high compression, but, C8AE-H was used on the 390GT which was around 10.2:1 so the mechanic might have made him a 390GT. they are good heads, the standard valve size is 2.03/1.56 you might bump back his timing and have it run on premium fuel, just out of curiousity, what kind of gas milage does he get? and does it have a 2v or 4v carb
Old Jul 26, 2001 | 08:36 PM
Honored1's Avatar
Honored1
390 Heads
Its got a new Carter 650 AFB on it and it was getting terrible gas mileage. Around 6 - 8 MPG on pump fuel. I am going to suggest that he find someone willing to trade him some 70's 390 heads from a truck for his. I don't think he will have much trouble finding someone to trade him. According to my manual the 390 came in 1968 with either a 2 barrel or a 4 barrel carb. The two options had very different compression chamber sizes (and consequently compression ratios!) With the 2.03 valves were these from a 4 barrel engine? That's my supposition. Thanks for all the help.
Old Jul 26, 2001 | 09:02 PM
Honored1's Avatar
Honored1
390 Heads
By the way, give me a ballpark guess what these heads are worth. The will need new valves, but the guides were new 8,000 miles ago.
Old Jul 26, 2001 | 09:05 PM
dfisher1's Avatar
dfisher1
390 Heads
You've got a hot rod on your hands. There are some problems and some solutions. No matter what you do, if your towing, your going to get bad gas mileage. The truck is heavier than most and the more horsepower, the better. Secondly, those 1968 heads do not have stelite valve seats. Running it on unleaded gas is a death wish for the valve train. You probably already have the heads pulled since you know the valve size, right? Get a valve job and run premium gas with a lead substitute. Retard your timing to 4 degrees BTDC. If your really concerned about the compression there is a old trick for the desperate; install two head gaskets to increase deck height. This is not a cure all, in fact, it can be a disaster. Intake seals may not fit after this modification. But, if the block has been decked and the heads machined it will work well.
Good Luck, Have Fun,
Kingfisher
Old Jul 27, 2001 | 12:15 AM
FE427TP's Avatar
FE427TP
390 Heads
The difference was more in the pistons. From what I have heard and seen there is no difference between the C8AE-H head and the D2TE-AA head (which is the only new head after 1972 that I know of) the D2TE-AA had some of them with hardened exhaust seats from teh factory for emmisions regulations and unleaded fuels. Nope nothing special about the valve size, that was the standard smallest size for a FE, the FT industrial engines had smaller valves, and bigger chambers, but you need the matching intake to use them.
Old Jul 27, 2001 | 05:38 AM
jowilker's Avatar
jowilker
390 Heads
Donald, If your dad can't handle that engine, have him bring it to Durham NC and He can have the 352 with 7,000 mile on the rebuild out of my truck. I would like to see him happy. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jul 27, 2001 | 08:53 AM
karljay's Avatar
karljay
390 Heads
I have a 360 that runs 180# of compression and it handles pump gas with no problems. I also have a 428 that runs 210# or compression and I also run pump gas on that as well. I think the 180# is normal for a 8.5:1
The C8AE-H heads are very common on the trucks and you should not consider trading them. If you already have them off, I'd polish the combustion chambers and reinstall them. 180# is NOT a problem, that is what you should have for a stock 390. Some truck got the lower compression pistons (410 pistons in a 390) but this reduced the squish effect and was a bad idea.
Keep the 180 compression and look elsewhere for the problem.
By the way, what was wrong with the engine? How did it run? was it pinging?
I really think your looking at the wrong area, but we really need some specifics about what the engine was doing to give intellegent answers.
Old Jul 27, 2001 | 11:31 AM
PetesPonies
390 Heads
These are not high performance heads. They are run of the mill FE heads; not bad, just common. The valve sizes are the same for almost all FE heads, except the high performance heads. This being so, there is no reason why this engine would not run well. I had these heads on my original 360, which ran great until I added the 428. The 428 has early ( 61) heads with slightly bigger combustion area, but more CID to squish into it also. I have no problems with pump gas. I would check the ignition timing to see what it is running, both initial and total. If the heads are off, have them adapted to stainless seats.
Pete's Ponies
Old Jul 27, 2001 | 11:46 AM
PetesPonies
390 Heads
DC Ranger
Mar 2, 2011 11:28 AM
shiftless
Oct 27, 2006 10:11 PM
rusty70f100
26
May 26, 2004 08:58 PM
misfit76
Dec 24, 2003 08:31 PM
sflorea
Sep 30, 2003 11:23 AM
