390 Compression Test PSI
Old Feb 1, 2011 | 04:57 PM
DC Ranger's Avatar
DC Ranger
I was talking to my buddy the other day and he had some "Mechanic" come and check out his 72 F-150 Custom with a 390. The "Mechanic" did a compression test and told him that it was at 200 psi and that is too high. I was trying to find some info about what psi you should get when doing the test and it looks like 135-150 (+or- 10% for all the cylinders) is normal. I went to take a closer look at his truck and I think it has cobra heads on it, I am basis this on the 200psi compression test number and the very nice looking valve covers that say cobra on them. I was just wondering if this sounds correct.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Feb 1, 2011 | 07:45 PM
ekm71f100's Avatar
ekm71f100
well just bc the valve covers say cobra on them, dont mean they really are. i have cobra valve covers on my 302 haha, just bc they look really cool. and another thing, i would double check on that comprassion test, that sounds really high, even if u did have the cobra heads. what are the casting numbers on the heads?
Old Feb 1, 2011 | 09:01 PM
akforceten's Avatar
akforceten
the 390 I put in my truck I got from work . It was board 60 over and had 50 psi oil pressure and the compression was 140 to 150 psi. an that was considered good!
Old Feb 1, 2011 | 10:11 PM
wyoming4x4's Avatar
wyoming4x4
200 psi ???
did you check all cylinders or just one. Is gage good? 200 psi is getting up their and fuel will be a issue if running low octane. need some more info.
Old Mar 1, 2011 | 10:21 PM
Ford_Six's Avatar
Ford_Six
I got 180psi out of a built 300-6 with 9.8:1 + compression, so 200 isn't outrageous. It is a bit excessive for a street engine though.
Old Mar 2, 2011 | 11:28 AM
Danger_Dave's Avatar
Danger_Dave
dont know about what it should exactly be. mine on all cylinders was around 120, with cylinder 7 at like 105
i believe what is key is that all the cylinders are somewhat uniform and even if the engine is worn, what you are looking for is them to be within a certain amount of each other and evenly worn.
but then you should also have a leakdown test done.
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
NEMOTORCARS
75
Nov 6, 2013 07:08 AM
TexasEX2K
Jul 5, 2012 10:46 PM
ABF PSD
Feb 9, 2012 09:26 PM
jt371
Jul 27, 2011 08:09 AM
