Diesel?
Old Jan 26, 2006 | 10:32 PM
RaiderfanBrad's Avatar
RaiderfanBrad
Diesel?
I have a 79 F250 Crew Cab. I am tinkering with the idea of installing a 7.3 N/A from a 91 during the restoration (if I ever have the time and money). I already have a strong running motor. Has anyone ever tried this? Would it be worth the time/effort? any comments.
Old Jan 26, 2006 | 11:51 PM
fellro86's Avatar
fellro86
It has been time and again, you have to like the diesels to begin with though. They behave a little different than a gasser, but the fuel economy and the pulling torque can't be matched. Go turbo and really get the numbers... From what I have read around here, the install is fairly simple as far as swaps go, but keep in mind that the front will be heavier with a diesel. If you choose to do it, be sure to get a trans with it as well.The bell doesn't quite share with a gas engine.
Old Jan 27, 2006 | 06:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Brad to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 27, 2006 | 08:03 AM
User 71024's Avatar
User 71024
You have to be a diesel guy to like a diesel truck and you wont know that until you do it. I've had both, and for a WORK or TOW vehicle the diesel can't be beat by any GAS setup, but for a dailey driver I'd stay with the gas.
Old Jan 27, 2006 | 06:31 PM
RaiderfanBrad
I've had multiple Diesel trucks over the years and have really had good luck with all of them. I'm just not sure how easily the conversion will go. Not many 79 4X4 Crewcabs around and I'll bet not many people have put a Diesel in one. Just thinking about trying something different.
Thanks,
Old Jan 31, 2006 | 09:25 PM
1978Crew's Avatar
1978Crew
fordcummins.com
check these guys out. They have done this conversion.
Old Jan 31, 2006 | 09:37 PM
Terran's Avatar
Terran
...for about 10k. That site allways comes up,but there must be a better
(and cheaper) way.
Old Jan 31, 2006 | 09:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are a number of threads here in this forum and in engine swaps on the conversion. It is not easy or cheap.
Old Feb 1, 2006 | 12:20 AM
DaveBowman's Avatar
DaveBowman
With a 7.3?
Old Feb 1, 2006 | 04:25 PM
Terran's Avatar
Terran
I suppose a 7.3 would get worse gas mileage than my 302 anyway.
Edit: It seems like one would get about 15-20mpg unloaded. I wouldn't mind that in my '79 F-100 project, mmm 300ft-lbs of torque.
Old Feb 4, 2006 | 07:39 AM
pauls painting's Avatar
pauls painting
i am putting built 6.9 turbo in my 76 s/c 2wd had to do modifications to front crossmember and had custom mounts made 400-500 hp 700ft lbs torque.......and she runs on waste motor oil so costs nothing to drive her
Old Feb 4, 2006 | 10:52 AM
DaveBowman's Avatar
DaveBowman
I don't want to hijack too much here, but I have to know what your doing to get 400-500 horsepower from a turboed 6.9?
Old Feb 4, 2006 | 12:46 PM
pauls painting
i lowered the compression to 17.1 and had pistons ceramic coated so i can run more boost also have head studs will also add water/methanol in it
Old Feb 4, 2006 | 12:48 PM
DaveBowman's Avatar
DaveBowman
I still dont see 400 HP from that. Don't get me wrong, it would be a good runner, but I think you overestimated your figure a little
Old Feb 4, 2006 | 01:38 PM
pauls painting
thats what i am hoping for. at least 300+ its going to be real hard to start when cold out , just want to use it to tow 5er with out losing power on hills.
t_dickie
Sep 14, 2010 04:50 PM
bmenzel
Sep 21, 2007 03:34 PM
red2003
Aftermarket Products
Aug 5, 2005 05:39 PM
cwb
Jan 16, 2004 03:56 PM
