Fuel Pump Wiring Question
Old Jan 26, 2006 | 10:51 AM
p8ntballn2's Avatar
p8ntballn2
I was under the truck the other day changing my oil.. since i have the 9" lift and 38" tires.. i can just sit indian style under the truck and do all the work.. so i was looking at what i thought to be the fuel pump.(inside drivers side frame rail).. cuz i had been reading up on how to drain it if there is water in there.. so i noticed that just to the right of that screw/bolt that you loosen to drain water.. there is a plug on the box (right side).. total of 3 of them.. and only 2 are plugged in... the bottom one is not plugged in.. the wire and connection are there but they are unplugged.. i bought this truck used 2 months ago.. and this is the first time i've noticed it... OASIS report showed nothing ever being done about the fuel system or anything.. i'm at work now.. but will take pictures 2day when i get home and post them so you guys can see what i'm talking about if this is unclear. no codes, no lights.. runs awesome and has awesome power.. espically w/ no muffler now.
2003 F350 CC King Ranch SB 62K 9" lift, 38" tires no problems as of yet...
Any help would be awesome
I'll get pics up tonight
Old Jan 26, 2006 | 08:07 PM
p8ntballn2's Avatar
p8ntballn2
this is the plug i'm talking about pointed out w/ red arrows
Old Jan 26, 2006 | 09:11 PM
PSD6litre40's Avatar
PSD6litre40
I believe that is the WIF (Watre in Fuel) sensor. You may have a bad sensor and was unplugged so the WIF wasnt illuminated.
Old Jan 26, 2006 | 09:28 PM
p8ntballn2's Avatar
p8ntballn2
hmm.. i'm thinkin i should try plugging it back in.. and see what happends.. maybe tomorrow when i get home from work.. i'll plug it in then start it back up see what happends..
Old Jan 26, 2006 | 10:48 PM
Btravelen's Avatar
Btravelen
Yep. http://dan.prxy.org/Truck/6L_bible_h.../Page_029.html Water in Fuel sensor plug. Likely what he said.
Old Jan 27, 2006 | 07:29 AM
Maxium4x4's Avatar
Maxium4x4
Kind of like the old days when you put a piece of tape over the Check Engine Soon light.......unplugging the WIF sensor did the trick
Old Jan 27, 2006 | 07:35 AM
PSD6litre40
It is not that uncommon for teh WIF Sensor to go out on these trucks. If the light comes on, just drain the water separator and see if the light goes off. If not, you have to have it replaced at the dealer I believe you have to have a special tool to R&R the sensor.
Old Jan 27, 2006 | 07:41 AM
p8ntballn2's Avatar
p8ntballn2
i'll just try draining it.. clean the connection..cuz it looks pretty dirty.. plug it back in and if it comes on.. i'll just leave in unplugged.. i really dont need it to be working.. i'll just drain it every now and then.. thx for all the help guys.. much appreciated..
Old Jan 27, 2006 | 11:10 AM
ALASKAF250's Avatar
ALASKAF250
Sweet rig
Old Jan 27, 2006 | 11:46 AM
p8ntballn2's Avatar
p8ntballn2
thx.. it turns heads everywhere i go
Old Jan 27, 2006 | 11:51 AM
PSD6litre40
I would highly reccomend your WIF light be functional. It could show signs of an extreme case of Poor Fuel.
Old Jan 27, 2006 | 12:08 PM
p8ntballn2's Avatar
p8ntballn2
i'll try plugging it in 2nite.. cuz i'm at work now and have nothing to clean the connection with.. i wanna clean the connection first.. b4 i plug it back in.. i'll let you guys know what happends
Jymmm
21
Apr 3, 2019 12:52 AM
bbender85
Jun 18, 2018 11:22 PM
RubberDuck
79
Jan 11, 2013 07:20 PM
akamacgyver
Nov 19, 2011 07:08 PM
Festus Hagen
20
Mar 21, 2011 10:35 AM
