1978 - 1996 Big Bronco
Tire size Question
Old Jan 31, 2006 | 09:14 PM
  #31
Streetgang's Avatar
Streetgang
There is a ton of room under there, if you want a wide stance why not just go with some other wheels with a offset that better suits you.....like with wider tires and that. I dont like the spacers because they are weak.
Old Feb 1, 2006 | 11:06 AM
  #32
poffutt's Avatar
poffutt
Originally Posted by 1990fordbronc
hey this is my truck and i was just wondering if a 3" lift with 33" tires and spacers would go well with what i have...im going for a certain look and i dont know i just want something a little bulky, wider stance, and not over done...tell me what you think and any ideas on what else i could do to make her look a lil better.. thanks
I got your same bronco with a 3" lift and 33" tires, just look at my gallery
Old Feb 3, 2006 | 12:08 AM
  #33
Fleet Bronco's Avatar
Fleet Bronco
Tire sizes
33x12.50's look and work great with a 2-3" lift, without a lift think they probably will rub and do body damage (not good). I put 32x11.50 BFG AT's on Ameican Outlaw 15x8 wheels on my '90 Bronco without a lift (it does have the HD Quadra Shock Trailer Towing Package) and it looks great! Almost looks like it's lifted, I have absolutely no clearance problems or rubbing even at full wheel lock, doesn't seem to have lost any performance either with 3.55's. Lots of opinions about tire sizes and lifts.
Old Feb 3, 2006 | 09:51 AM
  #34
lbianc1's Avatar
lbianc1
okay this guy off of this site in his description says he just put 33" tires on it and say nothing about a lift...that is the look im going for right there where the tires stick out a little bit past the body and are taking up a lot of the wheel well but still have the truck be functional anymore input on this?
Thats my baby. Its before I put the stronger coils on the front end. In that picture I have 33"x12.5" tires on stock suspension. I would not suggest doing this unless you plan on lifting it. They rubbed when I'd make hard turns which I do alot b/c I like to show off the awsome turning radius Broncos have.
Recently to fix the rubbing problem I put stronger coils on it which gave it a 2" lift in the front. I also upgraded the shocks but that did nothing as far as lifting it. The stronger coils did the trick and the tires don't rub now. I may raise the back by putting blocks on the leaf springs but that is not neccesary.
The springs were cheap, I got them from a local 4x4 place but you can also get them from jeffsbroncograveyard.com.
here is a link:
http://broncograveyard.com/bronco/i-...veling_kit.htm
I put new pictures of my Bronco with the lift in my gallery. I will try and put them on this post but if it doesn't work, look in my gallery. The lift gave me alot of room as you can see on the pictures and I now have the look and feel I was going for which is the wide stance, slight lift, still practical deal.
the pics are from my phone so they look grainy.
Old Feb 4, 2006 | 03:43 AM
  #35
Fleet Bronco
Totally awesome looking! Broncos gotta be the best 4x4 rigs ever built.
Old Feb 8, 2006 | 11:35 AM
  #36
1990fordbronc's Avatar
1990fordbronc
Poffutt:nice truck man i really like it. i have clear corners on my truck under the blackouts but next to my old head lamps, they look way too nice and clean because my headlamps are dinngey yellow and faded and not so clear. but i really like my black outs better than my clear corners. also too im loving the stance on your truck! your truck looks great!
lbianic1:yea man i was looking through the site for something that appealed to me and i came across your truck and it was looking nice. i really like the dual front shocks.i wish mine came with that package. i really like the stance on your truck as well and i love the push bar where did you get it?!?!?As for local stores, im actually 15 minutes away from the LMC Truck store and warehouse so i just drive up there to get my parts. i havnt checked but i dont know if they have upgraded suspension.
THANKS TO EVERYONES FEEDBACK AND YES BRONCOS ARE DEFFINATELY THE BEST!
Old Feb 8, 2006 | 04:26 PM
  #37
lbianc1's Avatar
lbianc1
I wish I could tell you where I got the bar from but that was the first thing I put on the truck when I got it in 2000. Thats way too long ago for me to remember.
I do know it was fairly inexpensive. Less than $200, maybe $150 or so.
In the near future I'd like to build a little bracket on it so I can mount a winch.
Old Feb 8, 2006 | 07:05 PM
  #38
1990fordbronc
not a bad idea. i see some in jcwhitney for like 100 or something like that but it just aint the same for me if i dont get to see something in person..i dont know if i said this but i like you dual front suspension! i wish i had that option on my truck..
