460 stroker
Old Jan 25, 2006 | 03:23 PM
bshackelford711's Avatar
bshackelford711
460 stroker
what is the best block to put a stroker kit into?
I am wanting to build a wild 460 stroker and have alot of horses rolling out of it.
what would you guys so go with?
What year and the best place to find it. (truck or car and what year)
Thanks
-Brandon-
Old Jan 25, 2006 | 04:30 PM
CD79F150's Avatar
CD79F150
Blocks
Any 460 block you can get your hands on. On the 460ford.com forum the guys their had a block summit, they sonic tested over 25 different blocks and found that no one block had an advantage over other. Some guys like the D9TE out of 80 and up trucks because the cylinder walls are .25 inch longer, to give better piston support at the bottom of the stroke. The majority of these blocks will take .080 overbore, but should be sonic test to be safe. Many people are making over 800hp with these blocks
Old Jan 26, 2006 | 12:14 AM
monsterbaby's Avatar
monsterbaby
here is the web page that Dave McClain put up for info on that block summit, it was actually 36 blocks checked and this page lists the differences of the different castings of blocks but the wall thickness really didn't show any patterns for years. If you click on the link at the bottom of that page it will come up with all the test sheets for all the blocks so you can see that info for yourself. I am running the D9TE block on my stroker for the exact reason CD stated the longer cyl walls work a little better for stability. (my block is picture #3 of the test sheets if your interested) but other than that I would say use whatever block you happen to have because they will all work.
http://www.fidnet.com/%7Efrd427/blocksummit.html
393STROKER
31
Jun 20, 2009 12:23 PM
70torino429
Jun 4, 2009 12:17 PM
stroker_8
Mar 16, 2009 09:00 PM
darrin1999
Oct 2, 2006 01:54 PM
Goodold71
Oct 19, 2003 03:39 PM
