possible vacuum problem
Old Jan 24, 2006 | 11:08 PM
detmerdj's Avatar
detmerdj
just dropped a 460 in my 77 highboy. runs good but when i try to climb somethin from idle it dies out. example: trying to drive up a curb. i have msd everything and it dosent have a vacuum advance, the engine is mildly built. i dont have any vacuum goin to the carb its a 770 truck avenger. just vacuum to the tranny and power booster. any suggestions?
Old Jan 25, 2006 | 06:48 AM
T18skyguy's Avatar
T18skyguy
Just a couple ideas. Put a vacuum gauge on the carb. You should see 18-20 inches at idle. Rule out any leaks in yur booster by disconnecting and plugging at the manifold then drive it and see if any better. Check any hoses or plugs for leaks. Could also be a carb or accelerator pump issue? How bigs your carb?
Old Jan 25, 2006 | 08:33 PM
detmerdj's Avatar
detmerdj
i just checked the vac gauge and it is 19-19.5 consistent. the carb is a 770 cfm with a stock manual fuel pump. also i have a new booster and for some reason there is no pedal pressure and the pedal stays down when u floor it. but when engine is off you can pump it and make the pedal hard. im stumped on this one i believe its a vacuum issue but not sure.
Old Jan 25, 2006 | 09:37 PM
T18skyguy's Avatar
T18skyguy
What does the vacuum gauge do when you mess with the pedal? Ive read about this situation here before a while back. Somebody had the answer-maybe the Gashog? Sounds like the brakes are not bled or the master cylinder is not primed correctly. Did you prime the master cylinder on the bench?
Old Jan 25, 2006 | 09:54 PM
detmerdj's Avatar
detmerdj
yes i did all the brakes correctly but im more concerned with the power problem my msd dist. dosent have a vacuum port so there isnt a vac advance what else could b the problem?
Old Jan 26, 2006 | 12:24 AM
Bear 45/70's Avatar
Bear 45/70
I suspect the problem is the accelerator pump adjustment. Not enough squirt soon enough for heavy load, ok for light or normal accelerating.
Old Jan 26, 2006 | 10:54 AM
T18skyguy's Avatar
T18skyguy
I wonder if the advance on the MSD is coming in too late-maybe a spring or weight change might help.
mark vanford
Oct 14, 2024 12:31 AM
solo pilot
39
Jan 16, 2014 11:16 PM
bruno2
Mar 16, 2012 08:38 AM
mh34444
May 29, 2010 06:40 AM
