weird windshield
Old Jan 25, 2006 | 02:57 PM
slothshady's Avatar
slothshady
weird windshield
hello, i was wondering if any of you deal with this same problem.
on the drivers side of my windshield the wiper blade skips and hops over part of the windshield.... especially at higher speeds. and there is one segment that it NEVER touches unless i push the blade down with my hand while its over it. the passenger side works perfectly. it did this with the last set of wiper blades i had on there too.
any suggestions on how to fix this?
Old Jan 25, 2006 | 03:04 PM
ford390gashog's Avatar
ford390gashog
the wiper is bent. try bending it (not the arm) . also anything other than the trico snap lock blades will hop on these windshields.
Old Jan 25, 2006 | 03:20 PM
1975Ford's Avatar
1975Ford
ford390gashog, good post, just like to add, Use The original metal wiper arm which hold the wiper blades. I like using the wiper blades with the metal slats running the length of the wiper blades. Are the truck wiper arm original, or are they aftermarket?
Old Jan 25, 2006 | 03:22 PM
ford390gashog
those are the oem trico blades. i will pull up the part number.
part # 46150 www.kragen.com
Old Jan 26, 2006 | 12:41 PM
slothshady's Avatar
slothshady
thanks for the replies guys. are you talking about bending the actual blade part? ive done that, but it normally goes back to how it was after a short period of time.... ill just stick it out and cake the windshield with rainx.
Old Jan 29, 2006 | 09:14 AM
eedvark's Avatar
eedvark
This is common on 73-79s i thought id be smart and put longer wipers on mine that did not help .That dry spot gets real annoying in the GREAT WHITE NORTH.
Old Jan 29, 2006 | 10:23 AM
oldhalftons's Avatar
oldhalftons
you cant use longer blades, they have to be 15"
Old Jan 29, 2006 | 01:58 PM
Mil1ion's Avatar
Mil1ion
This is a common problem with the original wiper blades .
Mine is on the passenger side.
You can always clip those aftermarket wiper blade *spoilers* on them
Old Jan 29, 2006 | 07:30 PM
theonlybull's Avatar
theonlybull
16" will fit with out a problem, but it does make the center lift worse at times
Old Jan 30, 2006 | 08:28 AM
1975Ford's Avatar
1975Ford
The original metal wiper arms work best, then using the original wiper length works best on those original ford wiper arms. I once used the longer wiper blades and had the same problem of the wiper not cleaning properly.
When I wash my truck, I will use a towel to wipe the wiper blades of any grude or dirt build-up, which accumalates during wiper use.
Old Jan 30, 2006 | 10:47 AM
roushracing617's Avatar
roushracing617
I currently have 16" blades on my 78. In short, they suck. I'm going back to the 15's. Lesson learned.
Vsanzbajo
Mar 19, 2014 10:23 AM
Pappys53
Jan 13, 2012 01:43 PM
GreatNorthWoods
13
Sep 2, 2010 06:43 PM
rob1994AerostarAWD
Aerostar
Dec 25, 2008 08:33 AM
BlueOvalFitter
2004 - 2008 F150
31
Dec 26, 2007 09:10 PM
