steering box leaking
Old Aug 5, 2001 | 01:01 PM
vettman's Avatar
vettman
Rebuilt steering box on my 2WD 76 F350 supercab with 460 is leaking pretty badly. I'm not sure I want to go with another re-manufactured unit. Is it possible to get a new after-market unit? Local dealer doesn't have one. This one works okay except for the leak(s).
Thanks
Old Aug 5, 2001 | 03:21 PM
PetesPonies's Avatar
PetesPonies
Is it the pitman shaft seal that is leaking??
Pete's Ponies
Mustang RUSToration & Performance
Old Aug 6, 2001 | 08:47 AM
vettman's Avatar
vettman
Can't answer that right now. I need to do some degreasing and troubleshooting to determine where it's leaking.
Old Aug 6, 2001 | 12:43 PM
jowilker's Avatar
jowilker
John usually a topseal or the bottom seals will take care of most leaks. We just bought a lower kit for $10.00 sat. There are two seals stacked in there.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Aug 6, 2001 | 01:15 PM
beartracks's Avatar
beartracks
If it's the bottom seal you may also need the bushing to tighten the shaft up.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 6, 2001 | 04:06 PM
79Supercab's Avatar
79Supercab
Old Aug 6, 2001 | 05:28 PM
vettman's Avatar
vettman
Looks like it's leaking from the lower end--believe that called the sector shaft end (attached to pitman arm). Can the lower seals be replaced without removing the unit from the truck, e.g., Can both seals be pulled from the lower end, or does the inner one have to be "pushed" from the opposite end; can the seals be driven in with a bushing driver, or do they have to be pressed in. "Beartracks", I don't see a bushing on the lower end diagram in my shop manual--just a couple of spacer washers.
Thanks to all who are providing input to this--really appreciate all the good advice.
John
Old Aug 6, 2001 | 10:09 PM
shortbedford's Avatar
shortbedford
hey vettman you can do that repiar in the truck. what i have done is jack the front end up put it on jack stands. straighten front wheels remove pitman arm remove snap ring use screwdriver or somthing similar to pry out the seals not the easiest to remove but can be done new kit should have installation instr.
another way is to remove the pitman arm go up under the hood find the two bolts that hold the sector shaft in remove them and go back underneath tap the shaft with brass hammer or something else suitable that wont damaged the threads pull shaft out look through the top and you will see the seals down there long bladed screwdriver or punch to knock the seals out instal in reverse manor hope this helps
Old Aug 6, 2001 | 10:17 PM
shortbedford
hey vettman this is a follow up to the last responce if you remove the shaft you can use a bushing driver to instal the seals more difficult if shaft is still in there i have also used a piece of pipe or socket the same outside diameter of the seals to instal them. depending on the year of that truck ford used to use the housing of the gear box as the bushing later years went to a needle bearing
Old Aug 7, 2001 | 08:27 AM
vettman's Avatar
vettman
"Shortbedford", thanks for the suggestions/advise. I may just give this a try this weekend.
Old Aug 7, 2001 | 10:21 AM
beartracks's Avatar
beartracks
It's been a while since I worked on mine but I think I bought a seal kit that included a think bushing to replace the washers. They may fall out then you get the seals out.
1977 Ford F-100
280,000 miles
Cazman1955
Feb 1, 2016 05:12 PM
Jkenosh
Oct 13, 2015 08:47 PM
anthonym92
Jul 29, 2015 03:46 PM
wantahertzdonut
15
Jun 27, 2015 09:58 PM
pgguru
Mar 7, 2015 01:18 AM
