front axel tag
Old Aug 9, 2001 | 10:18 PM
welder4life's Avatar
welder4life
front axel tag
i have 78 f150 4x4 rear end gears gone front axel tag reads3.50 d8ta te 610049-5 what does it mean and what gears would the rear end gears be
Old Aug 10, 2001 | 07:16 AM
Chuck P.'s Avatar
Chuck P.
front axel tag
3.50 is the gear ratio, D8 is '78 for the year, it should be a high pinion Dana 44 in the front and a Ford 9" in the back. Quick way to double check ratio is lift one tire off the ground (open diff) turn the wheel/tire once around, count the number of times the driveshaft turns, should be 3 and 1/2 times if it has the 3.50's.
Old Aug 10, 2001 | 07:23 AM
Chuck P.'s Avatar
Chuck P.
front axel tag
fordboy_52
May 20, 2016 02:16 PM
edtmontana
Jan 29, 2016 09:58 AM
4x4flatbed
Jul 17, 2015 02:12 PM
ScottInTexas
Jun 11, 2015 04:12 PM
kendeno
May 20, 2014 09:12 AM
