2004 f250 superduty axel remove
Do you have a pic of what exactly you are talking about? The hub assembly should pull out as one unit after removing the snap ring and washers, then unbolting from the back of the knuckle.
Once removed, the axle should pull out through the knuckle.
This article might help:
http://www.superdutypsd.com/ball_joint_article.php
I guess I'm not following what you are trying to do. If you are removing the front axle it should be removed as the link I posted above. Maybe someone else can chime in to assist.
chris64
08-25-2009 06:49 AM
rmacinc
01-22-2007 07:39 AM
bartspedden
11-30-2003 11:26 PM
