what axel is in my 1982 f250 ? 603946-4
... and from the same link it appears to be a semi-floating Dana 61. I'd never heard of a Dana 61 before but Wikipedia says it's a version of the Dana 60 with different pinion offset so they could install taller gears (like your 3.00:1) Not clear if 4.10s could be swapped into it, but it does say that low geared Dana 61s are uncommon
As a side note, if you want this rearend for heavy duty use I would not start with a semi-float axle like this. You want a full float axle.
Drac
12-16-2007 10:34 PM
crazy4Fords
12-16-2005 06:47 PM
