rich rich rich carb help
Old 01-23-2006, 10:59 AM
dj53's Avatar
dj53
dj53 is offline
Fellas, I just had the motocraft 2150 rebuilt on my 390 and it is running very rich.The exhaust is so rich my wife is about to kill me because of my clothe.Does anyone have some good advice in adjusting and working with this 2 barrell. Plus, what would cause my engine oil to smell real strong of gas??? and why does my oil pressure gauge read 100lbs is this the kind of out put these high volume pumps make??/ Thanks and Go PiTT!!!!!
Old 01-23-2006, 08:39 PM
IowaTower's Avatar
IowaTower
IowaTower is offline
The gassy-smelling oil is due to the richness of the carb -- unburned gasoline is draining into your oilpan, thinning your oil, etc.
Old 01-24-2006, 01:03 PM
dj53's Avatar
dj53
dj53 is offline
any idea how to adjust this carb autolite 2150 as to make it less rich
Old 01-24-2006, 01:20 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Most of the time that problem is caused by a blown power valve. It can happen even with a new valve if the engine backfires thru the carb even once. It is a poor design. Holley used the same system and they have a check valve now that prevents blowing the valve. I have no idea if the Holley retrofit valve could be used on a Motorcraft carb.
Otherwise check your float settings.
benbuilder
Trading Feedback
08-22-2016 07:08 AM
jayjjcc
02-12-2014 11:29 AM
Rich in CO
04-08-2011 11:43 AM
true blue
01-18-2011 04:06 PM
Wakeboarder141
07-29-2004 08:44 AM
Quick Reply: rich rich rich carb help
