Who will pull who?
Old Jan 23, 2006 | 02:01 AM
351m_torque's Avatar
351m_torque
Who will pull who?
a friend of mine always brags about his supposedly bad 1994 350 chevy 4 speed 3/4 ton so i finally got tired of his mouth and raced him i have a bone stock 1978 f-150 4x4 351m automatic and i beat him by close to 6 truck lengths now he wants to hook them up..... so the question is who will pull who? What does everyone think?
Old Jan 23, 2006 | 02:03 AM
ford390gashog's Avatar
ford390gashog
he's got the weight what gears do you have? just try to hold him off long enough until his tires start spinning then he is alll yours.
Old Jan 23, 2006 | 02:29 AM
351m_torque
i have 3.50 gears and 33 inch swampers he has really low gears not sure what and bald 31's
Old Jan 23, 2006 | 02:36 AM
ford390gashog
you also have the torque multiplication factor in 1st gear he does not. so in 1st you could be putting down about 500 ft pounds he would only be putting down about 320
Old Jan 23, 2006 | 02:50 AM
351m_torque
so does he even have a remote chance? there is a liitle bit of money riding on this.....
Old Jan 23, 2006 | 03:32 AM
ford390gashog
it depends. if your tires break loose you will lose but if his break lose you will win. its a fine art really. have any buddys you could practice with?
Old Jan 23, 2006 | 04:02 AM
351m_torque
have any tips on how to do this (first time) should i put the transmission in 1 or stay in drive? should i just mash my brakes until he spins? i have a feeling his clutch will slip... but when he starts to spin should i floor it or just ease into it?
Old Jan 23, 2006 | 04:04 AM
ford390gashog
yes 1st. don't mash the brakes it will lock them up and he will drag you. you want them firm but not locked then ease into it.
Old Jan 23, 2006 | 08:28 AM
cwheel's Avatar
cwheel
Try and have someone take a video of this. I'd love to see it!
Old Jan 23, 2006 | 03:56 PM
351m_torque
anyone else have any comments or suggestions?
Old Jan 23, 2006 | 04:34 PM
78f250_rls's Avatar
78f250_rls
Is his a 2 or 4 wheel drive?
Old Jan 23, 2006 | 04:37 PM
351m_torque
his is also 4 wheel drive
Old Jan 23, 2006 | 04:42 PM
seventyseven250's Avatar
seventyseven250
You want your truck as heavy as possible during the pull for traction reasons. Full gas tank for sure. If you don't think he'll notice, I'd put some sand bags in the bed. If you wanted to be sneaky about it, I'd try to add as much weight inside the cab as you can. Find a fat friend.
Old Jan 23, 2006 | 04:43 PM
78f250_rls's Avatar
78f250_rls
with his being a newer truck, if it has auto locking hubs, make sure that both trucks are in 4 wheel drive or make sure he does take advantage and kick his into 4x after hooking up
Old Jan 23, 2006 | 04:52 PM
AD1995's Avatar
AD1995
If you are doing this on dry pavement. Clean those tires with a degreaser. Get the oil out and you should get better traction. Should need it though Good luck
