1978 - 1996 Big Bronco
Steering Issues
Old Jan 21, 2006 | 08:00 PM
greybullit's Avatar
greybullit
Cool Steering Issues
On my 90 Bronco i have some play in my steering, when going straight i can turn the wheel maybe an eighth of a turn or so without it moving the truck. Anything i shoud look for immedietly? Thanks
Old Jan 21, 2006 | 08:01 PM
Kemicalburns's Avatar
Kemicalburns
tie rods, ball joints all could be worn. the steering box may also be worn but that is a last ditch effort at fixing this problem. we all have it.
Old Jan 21, 2006 | 08:46 PM
Streetgang's Avatar
Streetgang
You can use the sector shaft adjuster screw to remove play from the steering, but like the other reply said.....you MUST eliminate any other items that are worn FIRST.....then if there is still play.....give the adjuster like 1/4 turnCW and see how that is.....????
Old Jan 23, 2006 | 09:04 AM
Kemicalburns
that adjustment screw like streetgang said must only be turned and tightend in small amounts. test drive it an see if that helps. otherwise you can cause the steering box to bind and lock up on you which could be bad if your driving in town for instance.
Old Jan 23, 2006 | 10:16 AM
greybullit's Avatar
greybullit
right on, ill do an overall check on everything, thanks
Old Jan 23, 2006 | 02:12 PM
Streetgang's Avatar
Streetgang
Exactly.....also you need to try it at like 1/4 turn intervals....after each time you move that adjuster, lock it back down and drive the truck. You will know its too tight when after a turn the steering wheel does not return to approximately 90% of straight on its own.
deereman2
36
May 2, 2024 06:14 PM
v10Excursion04
Mar 16, 2014 12:36 PM
tigerblood
Apr 16, 2013 06:46 PM
scatgo
Offroad & 4x4
Dec 10, 2011 04:49 PM
77429highboy
Jun 19, 2011 08:58 PM
