squeek/squeel while turning steering wheel
Old Apr 15, 2013 | 04:29 PM
tigerblood's Avatar
tigerblood
When I turn my steering wheel it makes a sound similar to worn brakes, I really only notice it at low speeds like in parking lots and turning at stop signs etc.
is this power steering related or brake relate?
Old Apr 15, 2013 | 09:36 PM
kermmydog's Avatar
kermmydog
Is your belt tight? What happens when you touch the brakes? Is the power steering fluid full? Are the pads wore to the wear bars?
Craig
Old Apr 15, 2013 | 10:01 PM
Ryan0214's Avatar
Ryan0214
Most likely your power steering pump. The reason it happens at lower speeds, when you are turning, etc, is because it takes more force to turn your tires when you are going slower, and your ps pump has to try harder. Check your fluid, see if it is full, and see how dirty it is. Keep in mind that brake fluid (or powersteering fluid) is clear. Most older trucks like these have brown - black fluid, and it is time for a fluid change. If new fluid doesn't do it, a new pump may be the answer.
Old Apr 15, 2013 | 10:06 PM
kermmydog's Avatar
kermmydog
Ford was known for pump failures also.
Craig
Old Apr 16, 2013 | 06:23 AM
bdelmar2's Avatar
bdelmar2
Fairly common symptom of a worn belt.
Check the wear indicator on the tensioner.
Old Apr 16, 2013 | 06:01 PM
tigerblood's Avatar
tigerblood
ill check all of the above, I was suspecting ps because the brakes work great just as they should and make no noise. Thanks everyone for givign me some things to look for, ill let you know what I find out.
Old Apr 16, 2013 | 06:31 PM
Encho's Avatar
Encho
The Southernmost Mod
Before doing anything else... measure the steering fluid level and top it, you're probably just lacking some fluid.
Old Apr 16, 2013 | 06:46 PM
tigerblood's Avatar
tigerblood
Ill check this first, thanks
dave1969
1983 - 2012 Ranger & B-Series
13
Apr 3, 2018 02:47 PM
Wheelman55
Aug 2, 2015 01:03 PM
texasjack
Jul 23, 2010 03:15 PM
moenko
Sep 4, 2003 01:51 AM
tempolraD
Feb 16, 2003 08:42 PM
