Offroad & 4x4
How much flex
Old Jan 20, 2006 | 11:21 PM
OffRoadF-150's Avatar
OffRoadF-150
How much flex
Does a 1979 F-150 with a solid front end and stock radius arms have a lot of flex. it seems to me that an arm bolted solidly to the bracket and axle wouldnt move much at all. Just wondering.
Will
Old Jan 20, 2006 | 11:28 PM
Franken-Truck's Avatar
Franken-Truck
I had asked this question awhile ago. I was told (and it makes sense) that the flex in the older trucks comes from the "squish" in the "C" bushings. You can get soft rubber bushings to help it flex better. You can also install Hiem joints on the radius arm ends to help some there. And there is the wristed radius arm (search ) which dramatically improves flex, as well as longer radius arms
To answer your question though, no the stock setup doesn't flex all that well.
Old Jan 20, 2006 | 11:29 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
nope, they dont...thats why a wristed radius arm gives alot more flex, and extended arms help some..
Old Jan 21, 2006 | 09:28 AM
teds74ford's Avatar
teds74ford
What are you guys talking about? I get mad crazy flex- when my frame torques about 6"
Old Jan 21, 2006 | 09:31 AM
The SnoMan's Avatar
The SnoMan
Something has to give as the frame is not that stiff. (unless you want to take the time to box it)
Old Jan 21, 2006 | 10:08 AM
MBBFord's Avatar
MBBFord
I personally don't think you need to box in a 73-79 Frame. They are fairly stout as it is.
But I don't get alot of flex out of my 79, but with a 6" supper flex lift I get enough for what I do. My all means it's not going to climb a 4" rock on one side of the truck, but then to I didn't want a rock crawler. (going 2.5 mph just doesn't excite me)
Old Jan 21, 2006 | 10:27 AM
BigBlockF-250II's Avatar
BigBlockF-250II
My '79 F-150 when it was in stock trim had decent, but not great flex for a stock truck. I will say though that my '88 F-250 can pearch a tire on a taller stump than my '79 could, however it does also have a 2.5" lift, and crazy amounts of frame flex (ext. cab, long bed). Since I've gotten the rear suspension done, the '79 will out flex the F-250 with nothin but rear flex alone (about 20" of travel in the rear suspension). When I get the front done I hope to be able to pearch a tire on a 36" tall stump.
Old Jan 21, 2006 | 11:37 AM
teds74ford's Avatar
teds74ford
Post pics. I wanna see!
As far as frame strength, I have no doubts that the frames are plenty strong, just not very rigid, compared to new trucks.
Old Jan 21, 2006 | 11:47 AM
monsterbaby's Avatar
monsterbaby
Those frames get real rigid when you weld in a 10 pt roll cage trust me.
Old Jan 21, 2006 | 01:09 PM
BigBlockF-250II
Sorry, no pics yet. Look for a complete buildup thread of my '79 (with pics) on here within the next couple months.
Old Jan 21, 2006 | 01:42 PM
76 F-150 390FE's Avatar
76 F-150 390FE
mine got pretty good flex when i dropped the drive side rear about 3ft+ in a hole and the passenger rear was on the ground and the front was too. i couldent get outta the hole that easily but all the wheels stayed in the ground and i could reach out the window and touch ground. i hope to have pics of it sometime soon its just a matter of my uncle gettin the pics on a cd (hes a chebby guy and of course he had to be there when it happend and just happend to have a camera)
NY-Ford-Lifer
2009 - 2014 F150
33
Nov 17, 2010 09:35 PM
FAB150
Feb 16, 2007 09:01 PM
BigBlockF-250II
Offroad & 4x4
Jan 17, 2006 08:04 PM
Chris_ce
Offroad & 4x4
21
Dec 3, 2005 01:15 AM
f150_514ci
Offroad & 4x4
16
Sep 30, 2004 03:52 PM
