Stalling
Old Jan 19, 2006 | 09:45 PM
OLSCHOOL's Avatar
OLSCHOOL
Stalling
On my '03 / 7.3 with a Banks Big Hoss Module system I recently experienced intermittent stalling while engine is warm and driving under light load, took it to the dealer for diagnostic and this was their summary: checked multiple codes, found after market chip causing engine stall, necessary to remove chip, check OK but found engine to surge,further tests found erratic ICP readings caused by missing retainer in IPR, replaced retainer, Check, OK.
My question: is there a way to test my Banks chip to see if it's faulty (this was a very expensive system and I'd like to make sure it's bad before replacing it, do they even go bad?), or is the 2nd check described (retainer missing on IPR) the real problem and not the chip?
Old Jan 19, 2006 | 10:21 PM
ltfox's Avatar
ltfox
I doubt it was your chip. The problem you describe sound like a IPR problem. The stelaership seems to always blame someone else(the chip) first and their product last.
Old Jan 20, 2006 | 12:16 AM
OLSCHOOL's Avatar
OLSCHOOL
Ipr
What exactly is the IPR and it's function?
Old Jan 20, 2006 | 01:55 AM
jtharvey's Avatar
jtharvey
IPR = Injection Pressure Regulator. It is an "electromagnetic valve to regulate the HP oil pressure on the engine to tailor the injection characteristics of the injectors." Taken from here:
http://cw-diesel.com/LuxSite/IPRInfo.htm
It may provide you with some more info about the IPR.
Old Jan 20, 2006 | 06:47 AM
ntan's Avatar
ntan
Hey OLie whenever you go to the dealership always remove any HP programs or chips from your truck. Set your truck to factory settings. If your truck is still under warranty, any HP modification on your eng. will void it. With a chip the first code you'll get is a error module code, second code would be your problem. you can't even get a readout on your comp. ID #. Your IPR was probably the problem.
Old Jan 20, 2006 | 06:51 AM
ntan's Avatar
ntan
Oh by the way OLie plug your chip back on and see if it's bad.
Old Jan 20, 2006 | 08:53 AM
OLSCHOOL's Avatar
OLSCHOOL
Thanks everyone
I am putting the chip back in today to see if there's any further problems. I appreciate youir input.
Easytime
Sep 16, 2014 01:05 AM
dpassarella
Mar 30, 2014 07:55 PM
Peterbilt376x
Mar 3, 2012 02:26 PM
kc 300EX
Mar 2, 2012 05:14 PM
fishmanndotcom
May 3, 2006 12:45 PM
