Sponsored by: Innova
Speaker Sizes
Old Jan 19, 2006 | 01:32 PM
pmasley's Avatar
pmasley
Question Speaker Sizes
I am getting ready to change the door speakers. What are the sizes in an '01 F250 Extended cab, front and rear doors.
Old Jan 19, 2006 | 04:44 PM
yeldaw's Avatar
yeldaw
6x8 I think'
Old Jan 19, 2006 | 09:22 PM
IPACA9's Avatar
IPACA9
Originally Posted by yeldaw
6x8 I think'
WINNER!!!
6x8 or 5x7 will be fine.
Old Jan 20, 2006 | 06:29 AM
pmasley's Avatar
pmasley
Are they the same sizes in the front and rear doors. I know that in the earlier models, they had something 5 1/4's rounds in the front doors and 5 x 7's in the rear pillars.
The speakers in my '01 just suck. I have an expensive set of 6 X 9 Jenson tri I want to put in the rear doors and was just wondering if they would fit before I tore the door apart.
Old Jan 20, 2006 | 07:02 AM
IPACA9's Avatar
IPACA9
They may fit. Have to take into account the depth of your 6x9's and also you will have to trim the metal a bit
Old Jan 20, 2006 | 07:14 AM
pmasley's Avatar
pmasley
I was not planning on cutting any metal, but if it comes to that, I will.
What is the easiest way to confirm the speaker grounds in the rear doors. Ford has changed the color pattern.
Old Jan 20, 2006 | 09:55 AM
IPACA9's Avatar
IPACA9
Tonight I'll post your colors. My way I usually go about finding the polarity is just cut the harness off about an inch from the speaker plug. Take a 9volt battery an touch the leads to the speaker. When the speaker jumps out at you then what ever wire is on the positive terminal is your positive.
Old Jan 20, 2006 | 07:02 PM
IPACA9's Avatar
IPACA9
<table bgcolor="#ffffff" border="1" bordercolor="#d3d3d3" cellpadding="0" cellspacing="0" width="635"> <tbody><tr align="center" height="18"> <td class="directwire_heading" width="135">Radio 12v
</td> <td class="footer"> lt. green/purple
</td> <td class="footer" align="center" width="135"> +
</td> <td class="footer" width="130"> radio harness
</td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">Radio Ground</td> <td class="footer"> black/lt. green </td> <td class="footer" align="center" width="135"> - </td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">Radio Ignition</td> <td class="footer"> black/pink </td> <td class="footer" align="center" width="135"> + </td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">Radio Illumination</td> <td class="footer"> lt. blue/red (dimmer) </td> <td class="footer" align="center" width="135"> + </td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">Factory Amp Turn-on</td> <td class="footer"> N/A </td> <td class="footer" align="center" width="135">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">Power Antenna</td> <td class="footer"> N/A </td> <td class="footer" align="center" width="135">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">LF Speaker +/-</td> <td class="footer"> org/lt. grn - lt. blue/wht </td> <td class="footer" align="center" width="135"> +,-</td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">RF Speaker +/-</td> <td class="footer"> wht/lt. grn - dk. grn/org </td> <td class="footer" align="center" width="135"> +,-</td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">LR Speaker +/-</td> <td class="footer"> gray/lt. blue - tan/yellow </td> <td class="footer" align="center" width="135"> +,-</td> <td class="footer" width="130"> radio harness </td> <td class="footer" align="center" width="100">
</td></tr> <tr align="center" height="18"> <td class="directwire_heading" width="135">RR Speaker +/-</td> <td class="footer"> orange/red - brown/pink </td> <td class="footer" align="center" width="135"> +,-</td> <td class="footer" width="130"> radio harness </td></tr></tbody> </table>
Old Jan 21, 2006 | 10:39 AM
pmasley's Avatar
pmasley
Thanks for the response. Now to take the rear door panels off. I understand that it is a PITA.
Old Jan 21, 2006 | 12:14 PM
RangerPilot's Avatar
RangerPilot
With the exception of my Ranger...I don't know of a vehicle where the rear speakers are easy to get to. Well maybe my buddy's Civic. But that's about it. They are always PITAs to get to.
When we did my dad's 1992 GMC stereo, I ended up pulling ever peice of trim in that truck, redoing the headliner, and getting new carpet. Also pulled all the seats out.
All that for four 4"x6" speakers...Went ahead and amped them and added a sub, why not lol, for all that effort.
curtainrod
Aug 11, 2014 03:49 PM
jake_c_19
Dec 15, 2013 09:13 AM
1997fordf350
Aug 1, 2012 10:31 AM
89BlueBronco
1978 - 1996 Big Bronco
Mar 14, 2012 08:22 PM
Kliphton
May 14, 2004 01:16 PM
