FUSE Location HELP
Old Jan 19, 2006 | 12:08 PM
slouis1948's Avatar
slouis1948
Question FUSE Location HELP
I have a 1964 F100 Custom Cab that has suddenly lost the brake light. the rear lights, the instrument panel light, and the dome light. Is there a fuse that is connected to all of these and if so, where may I find it? I looked all under the dashboard and can't find anything resembling a fuse panel. Could my problem be in the light switch? Any advice would be appreciated. I tried searching the forum but could not come up with an answer.
Old Jan 19, 2006 | 12:31 PM
mark alderson's Avatar
mark alderson
Look again to the left of steering column under the dash it is under there.
Old Jan 19, 2006 | 01:02 PM
drof46's Avatar
drof46
On my 64 f-100 the fuse panel is attached to the bottom of the headlight switch. Should be about 5 fuses. You will need to be a limber to get your head in there, but its there. Should be one of the two fuses closest to the dash.
jjurva
Nov 14, 2012 01:24 PM
idgit0488
Oct 25, 2006 01:13 PM
Billy4416
Electrical Systems/Wiring
Oct 5, 2004 06:29 PM
stevec999
Aug 14, 2002 11:45 AM
DWalker
Feb 28, 2002 02:38 PM
