95 e4od van to 92 e4od f150????
Old Jan 18, 2006 | 03:49 PM
Pacerguyel2's Avatar
Pacerguyel2
Question 95 e4od van to 92 e4od f150????
I am looking for a new e4od trans for my truck. It is a 92 f150 4x4 302 w/e4od. I know where there is one that needs rebuilt but it is out of a 95 e150 van w/302. The van is 2wd. Will these trans. be identical as far as bellhousings and internals? Can I take the back end off of mine and put it on the one from the van to make it 4wd?? This is where i am not sure of. Any help would be much appreciated. Thanks!!
Old Jan 18, 2006 | 04:21 PM
l-m tech's Avatar
l-m tech
the valve bodys and solinoid pack are diff. than the on in your 92,you would have to use a solinoid for pre 95.you would have to take the output shaft from your trans and install in the other.its the last part out of the trans and first to go in.good luck
Dodge-My-Cummins
Apr 21, 2020 12:51 AM
92 Red F150
Jul 9, 2010 09:46 PM
Broncoholic1
May 31, 2010 01:54 PM
Cfdchf
Jan 15, 2001 04:46 PM
