E4OD Flex plate question
Old May 31, 2010 | 01:14 PM
Broncoholic1's Avatar
Broncoholic1
Will a late 96 Flex plate on a E4OD mate up to an early 302 1971? 28 oz balancer. Or do I need a custom one to make it work?
I just swapped a 71 302 into a 96 F150 2WD Has a E4OD in it.
Trans not yet installed
Let me know guys
Thanks
Old May 31, 2010 | 01:21 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The engine balance changed sometime in the early 80's. The late flexplate may bolt onto the early engine, but it will not be weighted correctly.
I think you would need a custom unit for this application.
Old May 31, 2010 | 01:29 PM
Broncoholic1
I was hoping I could just bolt it up. Any Idea where to get one that will work?
Old May 31, 2010 | 01:34 PM
Rogue_Wulff
I don't know of anyplace in particular, but these trans are quite commonly swapped into older vehicles along with a stand-alone controller, so I'm sure there's something that works. For that matter, it's quite possible that an older C6 or C4 flexplate might work.
The key would be to search for info about swapping this style trans into an early model car/truck, as it's the same pricnipal as what you are doing by swapping an early engine into the late model chassis.
Old May 31, 2010 | 01:47 PM
Broncoholic1
You mean a new threat? 96 E4OD into a 71 F100 2wd?
Might get it here? I hope
Old May 31, 2010 | 01:49 PM
Rogue_Wulff
Nah, I'm sure someone will come along soon and see this thread, with the knowledge to accurately answer your question.
Old May 31, 2010 | 01:54 PM
Broncoholic1
Thanks RW
I am sure someone knows
1Austin112
Oct 27, 2016 04:25 PM
racer6huk
Aug 1, 2016 09:49 AM
BuickBrian
Jan 25, 2016 06:59 AM
NotSoSporty98
Nov 23, 2015 07:09 PM
Twistedwrench
WTB - Parts & other
Nov 6, 2012 06:36 AM
