Sponsored by: Real Truck
How to remove stock CD Changer?
Old Jan 18, 2006 | 12:43 PM
Dregsz's Avatar
Dregsz
Hi All,
My stock CD changer fried so I bought a replacement unit on ebay.
How do I get the old one out to get the new one in?
Do I need to remove the dash and how would I do that if necessary?
It isn't redily apparent?
Thanks
Evan
Old Jan 18, 2006 | 01:03 PM
F250Wheels's Avatar
F250Wheels
You should have four small holes in the face of the cd player, go to auto parts store and get removel tool. the tool goes in the holes and unlock player and pulls right out.
Old Jan 18, 2006 | 01:33 PM
Dregsz's Avatar
Dregsz
Thanks
THe new one doesn't have the din holes,
How does that one mount up, (or will it?)
it has holes on a frame below.
Evan
Old Jan 18, 2006 | 02:51 PM
bigblu250's Avatar
bigblu250
Or if you want to save yourself a few bucks and a trip to the quto parts store, you can try what I did when I repalced my stock stereo two years ago. Take a wire coat hanger and cut, bend, fashion it into two wide mouth U shapes. Simultaneously insert both ends of both U shapes into the holes and the thing will slide right out like butta'......
Don't know about the new unit, can 'ya post a pic if possible?
Old Jan 18, 2006 | 02:59 PM
function12's Avatar
function12
If your is a 2005 or newer. You need to pull the front dash cover off. The 2005-06 bolt to the dash. 04 and below have the din holes.
Old Jan 18, 2006 | 03:04 PM
ford390gashog's Avatar
ford390gashog
or just use 4 framing nails. one in each hole. works well. the tool is not worth the 13.00
Old Jan 18, 2006 | 06:43 PM
Dregsz's Avatar
Dregsz
I bought the tool for $7.04 including tax at Shucks.
It came out.
It turns out that my replacement unit is a newer bolt in model with a wide faceplate, so I took a #9 Torqz and took the frame off, swapped face plates and slid it in, like butta, I don't have blinding acceleration or go off road too much so it isn't likely to slide out. Vibration may be an issue.
Any Idea how to mount a set of DIN clips to it to make it like stock?
Thanks for the help.
Evan
bryyce62
Jul 17, 2011 02:03 PM
97flairside
1997 - 2003 F150
Jan 15, 2011 02:30 PM
gonzome
Jul 4, 2008 11:37 AM
D Ray
Dec 7, 2005 10:47 PM
hybridamp
1997 - 2003 F150
Aug 5, 2003 07:01 AM
