72 Power Steering ?
Old Jan 17, 2006 | 10:31 PM
oldmansimek's Avatar
oldmansimek
72 Power Steering ?
My 72 does not have power steering at the moment and for some reason the manual steering seems to be getting worse. I would like to put in power steering just wondering what I need the truck is 4x4 with a 360 manual trans floor shift don't want to change column.?
Old Jan 18, 2006 | 05:35 AM
jowilker's Avatar
jowilker
Hey oldman, haven't seen you in a while, what's up?
4X4s had some unique issues of their own. I bet you will get a good answer shortly.
John
Old Jan 18, 2006 | 10:30 AM
oldmansimek
Not much man, It's been getting harder to get answers on this site as time goes bye
hopefully I'll get something for the power steering or I'll have to go junkyard hunting or talk to some other ford friends around
Old Jan 18, 2006 | 12:43 PM
qman's Avatar
qman
Maybe a front end lube job? Or maybe a front end rebuild?
Old Jan 18, 2006 | 01:39 PM
oldmansimek
I know I can fix the manual steering easily but I would like to swap to power because I would like to go with bigger tires and it would just be nice.
Old Jan 18, 2006 | 01:44 PM
bertha66's Avatar
bertha66
I have a 66 F-100 4x4 that I did a Toyota conversion on. Works great.
Old Jan 18, 2006 | 09:20 PM
baitmaster's Avatar
baitmaster
My '72 4X4 now has power steering. bought the kit from the guy in Iowa, but ended up replacing a couple of the junkyard parts he sent me. A little cutting, a little welding, drilling a couple of new holes, and away i go. Sure is nice to roll those 33's around at a dead stop.
Old Jan 19, 2006 | 06:02 AM
jowilker's Avatar
jowilker
Oldman, I hate you have had trouble getting answers. I'm fairly good with 2wd, but come up short with the 4X4.
John
Old Jan 19, 2006 | 09:43 AM
oldmansimek
Thanks guys I'll piece something together
Old Jan 19, 2006 | 01:09 PM
bertha66's Avatar
bertha66
I did the Toyota conversion from wrecking yard parts for $275, including the machine work on the drag links. If you would like more infromation PM me you e-mail and I will send you the infromation on the conversion. Allen
Old Jan 19, 2006 | 11:41 PM
oldmansimek
Did ford ever make an FE motor with power steering if you know what did it come in and what years, this will answer all my questions about this problem
Old Jan 20, 2006 | 06:21 AM
jowilker's Avatar
jowilker
Absolutly most all of the 73-76s with 360s had ps. Most all of the cars in the 60s with 352s, 390s, 428s had it.
I think there are some issues with the early 4X4 systems though.
John
Old Jan 20, 2006 | 10:27 AM
bertha66's Avatar
bertha66
My Brother-in-law has a 75 F-100 4x4 with the power steering and tha 360 FE engine. It is a power asist. system, with a ram on the front of the tie rod. It does work good, but if it were to be bent while out 4 wheeling you would be in a would of hurt.
hoss73ford
May 30, 2015 03:35 AM
baitmaster
Jan 28, 2009 07:22 PM
BLstangin
Sep 1, 2004 09:15 AM
Bobber72
Jan 22, 2004 10:47 PM
Sunny_in_hollister
Dec 13, 2001 06:09 PM
