steering too easy?
Old Jan 14, 2009 | 06:55 PM
baitmaster's Avatar
baitmaster
steering too easy?
What can I do to firm up the power steering on my '72 F100? since I yanked the manual and went to power a few yrs ago, I don't get any feedback to the wheel. Maybe I just got used to manhandling the wheel with manual and 33" tires for 15 yrs. It just steers too darn easy.
Old Jan 14, 2009 | 08:43 PM
Alvin in AZ's Avatar
Alvin in AZ
Maybe it's got too much play in the system?
How much play has it got?
I used a tape measure so I wasn't fooling myself. (YMMV on that;)
Sit in the drive way and just rock it back and forth.
(and it's ok if you make BRRrrBRRrrr sounds while doing that;)
Alvin in AZ
Old Jan 16, 2009 | 01:26 PM
matejcekautoworks's Avatar
matejcekautoworks
on the top of your steering box there is a nut with a screw in it, and like tightning bands on a tranny, just loosen the nut then tighten the screw a half turn the tighten the nut, take it for a drive, if it works then YAY, but if not good enough yet, repeat the prosess
Old Jan 16, 2009 | 02:07 PM
Alvin in AZ
Yeah Mate but there's other things need looking into first tho. :)
Get someone to rock the steering wheel back and forth while you get under
there and feel for play in all the different joints in the steering system. Have
'em rock it short and long as you need it. You decide just how many of those
joints you want to replace/fix.
A worn steering gear's "bearings;)" will show themselves as the sector shaft
will -first- move to the side -before- it twists. (that was the big one for me)
There are threads about it and so far only know of one other guy that had
their steering gear line-bored, some have bought them all setup and ready
to go.
https://www.ford-trucks.com/forums/8...x-install.html
Alvin in AZ
ps- the machine shop needs to be setup to do the job already or it's like
$300 otherwise it's like $100, mine was $75 but I supplied the bearings ;)
Old Jan 16, 2009 | 08:51 PM
Ford_Six's Avatar
Ford_Six
Do not adjust this unless you have already replaced everything else in the system. Adjusting this when it doesn't need to be done will damage the box.
The Ford power steering system is overboosted, plain and simple. Nice when turning into a tight parking spot, but no feedback. This is typical of the era, though. Luxury features were for luxury, not performance.
One way to get some feel is to increase the caster, but that's not easy on these early I-beams. You might be able to find a shop that can do it, but not many have people with the knowledge anymore.
Old Jan 17, 2009 | 03:11 PM
mongoosekeith's Avatar
mongoosekeith
I am going to do a power steering and disk break conversion from a '79 F150 would it be worth it to do this swap.
I am 17 the truck is going to my daily driver here when i get my license in a couple of weeks. so lemme know
Old Jan 18, 2009 | 03:40 PM
matejcekautoworks
it is a worthwhile swap, but make dang sure that it'll work right, i think it will, just drop the beams from the center pivots and put up the new ones, i suggest changing all your bucshings while your under there. then swap in the mastercylander and booster(if acclabale) and bleed the brakes and that should do it, oh also try to get new brake parts and bearings, just to make it all the much better. i dont think the power steering boxes will intercgenge , but im probly wrong on that, but good luck anyways
Old Jan 18, 2009 | 09:33 PM
Ford_Six's Avatar
Ford_Six
Follow this article, and you'll be set:
https://www.ford-trucks.com/article/..._2wd_6572.html
Yes, the swap is worth it, I took a bunch of pics and have all the parts and tools needed listed out.
Old Jan 22, 2009 | 06:40 PM
baitmaster's Avatar
baitmaster
Thanks for all replies. I should have mentioned that this is a 4 wheeler, and there is NO play in any moving parts. I think Ford Six hit the nail. i can turn the wheel 1/2", and both tires start to move. Also had the wife tweak the wheel, while I was under there, and detected nothing that wasnt tight. Maybe when i get older, I will welcome this girly steering. This truck came from the factory with manual steering, which I manhandled for 15 yrs. So now I'm at the other end of the effort scale, which I guess is the better of two probs.
Old Jan 22, 2009 | 09:21 PM
Ford_Six's Avatar
Ford_Six
How's the steering set up? If you put on a Toyota box or similar and have the drag link going to the tie rod, watch for the tie rod twisting. That is normal with that style of steering, and will cause a vague and wandering feel. If you were to run the link to the top of the right hand steering arm, that would eliminate that source of play.
Old Jan 26, 2009 | 06:15 PM
baitmaster's Avatar
baitmaster
This was a kit I bought from a guy in Iowa several yrs ago. Nothing is dif from stock underneath, except a little cutting and welding. If I remember right, we cut the drag link, and steering rod. Would have to look to see what box it has on it, but I know its not a Toy setup. I dont get any wandering on the road, it goes straight and the truck feels tight. Its just doesnt take any effort to steer.
Old Jan 26, 2009 | 09:03 PM
shift1313's Avatar
shift1313
You have any steering dampers on there? maybe throwing a dual damper setup on there would give you some "feel". Every ford truck ive owned/driven with ttb erra stuff has always been very "easy" to steer.
Old Jan 28, 2009 | 07:22 PM
baitmaster's Avatar
baitmaster
stabilizer
I do have a single stabilizer on it. Maybe I should go to a dual setup, as this should provide a little more resistance. I'm sure the whole thing is the overboost that Ford Six had mentioned. But now that this is not my daily driver anymore, this prob has moved down the priority list.
wyoming4x4
Mar 28, 2018 07:47 PM
Sullid01
Sep 29, 2016 04:31 PM
AubreyA3
Jun 24, 2016 11:53 AM
jcweis1
Mar 28, 2015 09:42 PM
alvald83
Oct 24, 2009 04:34 PM
