engine question
Old Sep 3, 2001 | 01:18 PM
fordblue_ca's Avatar
fordblue_ca
engine question
Hey
My Brother has a boat with a 77 302 that runs great but....Something broke on the leg on the boat and so the cable got kinked and is stuck in gear. So its just been sitting for a about 3 months and it will sit until we can get it fixed. my question is should I remove the rotor and just turn it over so that the engine stay's oiled?, will this help?
Thanks alot,
Joe
Old Sep 3, 2001 | 01:44 PM
Like M. Fords's Avatar
Like M. Fords
engine question
The best you could do without starting it would be to squirt some oil in each spark plug hole and rotate the engine by hand a few revs with the plugs out. This will keep the rings and walls oiled up. As for the bearings, and lifters, you could get a oil pump pre-lube shaft that you chuck up to your drill motor and spins the oil pump drive shaft. You will need to remove the distributor to do this, but it is better than burnin out your starter motor and wearing down your batery. Your drill motor should be at least a 3/8 capacity and have reverse (counter-clockwise rotation) for a 302.
Old Sep 3, 2001 | 05:40 PM
jowilker's Avatar
jowilker
engine question
Joe if removing the rotor isn't a big production, nothing beats a running engine.
IMHO of course.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Sep 3, 2001 | 05:55 PM
fordblue_ca
engine question
So do you mean it would be ok just to turn it over for a minute or so???
Thanks for the reply's )
IMHO of course.
John
jowilker
66F100s Rule
Old Sep 3, 2001 | 09:39 PM
Matt67's Avatar
Matt67
engine question
Old Sep 4, 2001 | 06:32 AM
jowilker's Avatar
jowilker
engine question
I would really like to run the engine, but turning it over till the oil pressure came up would be good. It would be OK to do it with a jumper cable if needed.
There is no way to get the prop out of gear? Can you remove the cable, and manually shift it to neutral?
John
jowilker
66F100s Rule
Old Sep 4, 2001 | 08:34 PM
Like M. Fords
engine question
Will just spinning the engine with the starter be fast enough to splash oil on pistons to get the bores oiled? I think he should still at least squirt some oil down the plug holes first.
Old Sep 4, 2001 | 09:37 PM
jowilker's Avatar
jowilker
engine question
Not a bad idea, but three months is not 3 years. The engine should still be in good shape, as well as the gas.
John
jowilker
66F100s Rule
Old Sep 4, 2001 | 11:01 PM
Like M. Fords
engine question
Three months at sea is probably worse than three years on land.
I know, I know, the boat is probably on the trailer in his heated garage.
JOE33060
6.4L Power Stroke Diesel
48
Sep 11, 2011 07:35 PM
joemcco
Oct 23, 2009 06:33 PM
68m77f350
Apr 1, 2003 01:54 PM
joe460
Sep 17, 2002 01:48 AM
