Hopefully someone can help. My wife had this running, locked the doors, and used the keypad to open the doors. It seems like ever since then the driver side door lock won't unlock unless you use the key or pull the interior handle. The keyfob, keypad and switch won't work.
Can anyone point me in the right direction? As far as troubleshooting or where to start. I am guessing the switch first? Is there a code she could have pushed on the keypad to disable the driver door? I know usually the door doesn't lock when the truck is running.....
