obd code 0113
Old Jan 15, 2006 | 08:52 PM
ken8769us's Avatar
ken8769us
obd code 0113
i have a 99 ford expidition with 75400. the service engine light came on so i had it check with an OBD ll and code # 0113 came on. Now i have changed my 02 sensor bank 1 and resetted the engile light but after 200+ miles it came back on. Check it and same obd code came on. anyone knows whats going on? Thanks for your help.
Old Jan 18, 2006 | 07:46 AM
FTE Ken's Avatar
FTE Ken
Moved to proper forum. Not a chip/tuner question.
Old Jan 18, 2006 | 08:19 AM
01silvergt's Avatar
01silvergt
P0113 - IAT Circuit High Input
This is what I get for that code. Where did you get your code read / information on what it means? Sounds like you were on the wrong track. Need to replace the IAT sensor. Its located after the MAF on the air intake.
Are you sure its not P0131 that you got? That would be an O2 code for bank 1 sensor 1. Its not uncommon to have to replace a "new" O2 sensor with another new one b/c the last one was bad. If this is the code you have, then return the sensor and replace it with another one and see if the code comes back. If it does, then you need to trace the 2 white wires on the O2 cable and make sure they have proper connections on both ends.
jdgrier05
Jul 24, 2016 01:21 PM
blueline970
Feb 19, 2016 12:12 PM
Brian Hughes
1997 - 2003 F150
Sep 22, 2015 12:16 PM
hardwaterfreak
Aug 24, 2015 06:12 PM
PP Stroker
New Member Introductions
Jan 19, 2010 01:16 AM
