93 Explorer 4x4 Troubleshooting
Old Jan 15, 2006 | 07:41 PM
ajr2000's Avatar
ajr2000
I have a 93 Explorer XLT and the 4wd is not working. When I push the 4 wheel high or low buttons, nothing happens. The lights do not light up when pushed. I'm told that the passenger side hub needs to be replaced. I want to make sure this is it before I take everything apart.
I've heard that replacing the hub is easy, what exactly do you need to do? I see Ford sells a locking hub repair kit, is this what I need, or do I need to buy an entire hub?
Thanks for all your help.
Old Jan 15, 2006 | 10:46 PM
Jharger's Avatar
Jharger
Not sure who told you this but I bet they don't know a lot about early Explorers...if they think fixing a hub has any thing at all to do with an electronic shift system.
probably need to rebuild the shift motor assembly. Everyone eventually needs to do this. Did it on mine about a iyear ago at 170K miles.
Find out here on this web site. http://draco.acs.uci.edu/explorer/
Old Jan 16, 2006 | 08:32 AM
ajr2000's Avatar
ajr2000
So if I have just a bad hub, 4x4 will still work, but I would have 3 wheel drive?
My mechanic and the original owner of the car says the hub needs to be replaced, but the shift motor may need to be fixed too.
Old Jan 16, 2006 | 10:33 AM
Jharger's Avatar
Jharger
Pretty much that's what would happen. The shifting of the transfer case is electrically controlled. The turning of the axels is mechanical. the hub is the last link of the mechanical system. If it goes into 4WD, then the axels get driven and if a hub is bad it might do nothing or make a lot of noise - depending on what's wrong with it.
Old Jan 16, 2006 | 12:29 PM
ajr2000's Avatar
ajr2000
Thanks for the info. I now feel more motivated to fix this after driving today.
Old Jan 16, 2006 | 08:58 PM
puppypower's Avatar
puppypower
Hey Jarger, I was wondering if you got around to replacing your ball joints yet. I wanted to know how long it took you and how difficult it was for you to do. I did mine in my driveway with hand tools and a cordless 1/2" impact. It took me about 12 hours to do each side. But that was with cleaning all the rust up as I went along and also did brake lines to the calipers, rotors, calipers, pads, and front shaft u-joints. Oh yeah, bleeding the brake system also. All and all it took me the entire weekend to do the job. I was just curious. Chris
Old Jan 17, 2006 | 12:22 AM
Jharger's Avatar
Jharger
My U-joints
Hey Chris. No I didn't get to it yet. I just got the tranny back in last weekend. It blew on me 2 days after x-mas so I had a new priority - walk or fix the truck. Then this weekend my brother and family were in town for his wife and my wife to run the PF Changs marathon in Phoenix. And now my mother is here, leaving on Sat, so this next weekend is shot. Since I also need to pull my front diff and reseal the case, I'm into it for at least 2 full days. I've got all the parts and brake pads sitting on the bench...just need the time. I don't think I'll have any rust problems and I wasn't planning on changing U-joints since I've got less than 2,000 miles on the front running gear and any time I do engage it's low speed crawling or hill climbs.
live2hunt
Offroad & 4x4
Feb 17, 2007 05:52 PM
RA81222
1978 - 1996 Big Bronco
Nov 14, 2005 04:07 PM
Pubert
Mar 4, 2004 10:37 AM
Mike in RI
Jan 2, 2004 07:38 PM
logan
13
Nov 26, 1999 10:41 AM
