Making Your Own Tow Package??
Old Jan 15, 2006 | 04:02 PM
LilBlackCoupe's Avatar
LilBlackCoupe
Just got a new 2005 F150 Screw and it doesn't have the factory tow package on it. I need to pull a car and trailer back and forth to the dragstip safely. I've already got the hitch installed. What else should I do or what else has everyone else done to tow. Also... what's the easiest way to add electric traile brakes to my new truck??
Old Jan 15, 2006 | 04:12 PM
ford390gashog's Avatar
ford390gashog
the tow package came with larger radiator.tranny cooler,bigger battery, iv hitch, 7 pin hookup with brake wires and charge lead.
Old Jan 15, 2006 | 04:51 PM
fordman19762003's Avatar
fordman19762003
I think that all trucks with AC come with the larger radiator so all you need to add is a tranny cooler and whatever type of connector you need for your trailer lights. I don't have any experience with electric brakes so I can't help you there.
Old Jan 15, 2006 | 08:05 PM
Black92 5.0's Avatar
Black92 5.0
Thumbs up How to make your own tow package
I pull an 18 foot Keystone Springdale that weighs about 4000lbs fully loaded. I used to pull it with my 92 F150 2wd, 3.55, 302 5.0. To do this I too had to make my own tow package.
1. Upgrade rear shocks (if desired) to heavy duty shocks.
2. Add tranny cooler
3. Add class IV or greater hitch.
4. Add brake controller (Not hard to add but I had local RV dealer do this part for about $60 in labor and saved me ALOT of time)
Viola! your ready to pull.
I still have the ole' '92 and she pulls just as good as my 04 SC 4.6 2wd 3.55 with a factory tow package.
Old Jan 15, 2006 | 09:28 PM
ford390gashog
fordman,
the extra cooling radiator is by option only. the a/c trucks still have the standard cooling.
Old Jan 16, 2006 | 01:37 PM
KevinM's Avatar
KevinM
The brake controller only comes on the F250. The F150 trailer package consists of a class IV hitch, radiator upgrade, 9 channel aux trans cooler, 7pin wiring harness, 72Amp Hr heavy duty battery ( Ford 2005 RV @ tailer towing guide pub# RV-VER7254-0804). This is the optional trailer tow package that gets you to max tow capability for your rear and engine size.
Old Jan 16, 2006 | 02:01 PM
ford390gashog
we know the factory brake controller is only in superduties, but these trucks do come with the brake wiring for a aftermarket controller.
Old Jan 16, 2006 | 05:02 PM
simpson117's Avatar
simpson117
I also bought my 04' S-crew with no factory hitch. When I took it to have it installed I found out that it was already pre-wired for the brake controller. Just plug it in under the dash. I then had to purchase the 7 pin connector and wire loom that plugs in up by the spare tire. Bought both pieces from the local dealer for $77. Everything plugged right in and worked great no problems yet.
Old Jan 17, 2006 | 08:06 AM
KevinM's Avatar
KevinM
The only problem with just adding thwe hitch, your tow capacity is limited to the same weight as as stock unit with non of the other upgrades. Just putting on a hitch does not provide you the upper tow weights.
Old Jan 17, 2006 | 10:12 AM
thooor's Avatar
thooor
Tranny cooler clearance
Moss has tranny coolers on clearance.
http://www.f150online.com/forums/lin...eIndexID=51585
f150crewcab
May 16, 2012 08:30 AM
drh1175
EcoBoost (all engine sizes)
May 8, 2011 11:11 PM
msgtord
2009 - 2014 F150
15
Jul 19, 2010 03:11 PM
DoughboyRacing
1997 - 2003 F150
Apr 6, 2004 10:32 PM
Buckmaster24Fire
1997 - 2003 F150
May 21, 2003 11:38 PM
