Flame Thrower
Old Jan 20, 2006 | 11:16 PM
  #46
"Beemer Nut"'s Avatar
"Beemer Nut"
KJKozak2, the only reason to add a condenser is to reduce arcing of the contacts in the relay like a condenser in a points ignition system, not "to achieve "buzz"".
.....=o&o>.....
Old Jan 21, 2006 | 12:27 AM
  #47
"Beemer Nut"
The 0.1 to 102.3 seconds in 0.1 second increments 12 volt time delay relay can be had for $27.50 plus shipping to your area. Calif was $9.05 shipping, total $36.55. I purchased the timer thru skycraftsurplus.com or Google Skycraft Parts & Surplus. They're in Florida.
The timer is DPDT 10 amp contact rating, 12 volt coil, octal base included, digi-set, D.I.P. switch time set / selection. Part # TDML12DL. Sounds like you can wire both coils to the timer instead of the timer controlling extra relays.
Ivan, for Red flames, Lithium Chloride (LiCL),
Scarlet Red flames, Strontium Chloride (SrCL2)
White flames, Barium Sufate (barite
Blue flames, Cupric Chloride
Hope this helps.....=o&o>.....
Old Jan 21, 2006 | 01:12 PM
  #48
Scot's Avatar
Scot
There was a discussion of this over on the '48-60 forum a year or so ago. There is a circuit diagram to use a Duraspark box and capacitor/resistor to set the occillation frequency.
Old Jan 22, 2006 | 10:21 PM
  #49
KJKozak2's Avatar
KJKozak2
beemer nut,
Yeah, i didn't mean to say that the condensor achieves the buz, but that the relay AND condensor do. Without the condensor, you're right, the relay just arcs on the inside.
K.
Old Jan 23, 2006 | 12:43 AM
  #50
"Beemer Nut"
Scot and others interested in a ignitions for flamethrowers.
Go to a FTE members reply by 1short back in 3-7-02.
Check his photos, a Motorcraft ignition module (late 70's to early 80's) that is triggered by a 555 timer. A wrecking yard we go.
.....=o&o>.....
Old Jan 23, 2006 | 07:44 AM
  #51
KJKozak2's Avatar
KJKozak2
Yup. The 555 timers from radio shack along with a variable ohm resistor and a few other parts will work also. Just make sure you have a good soldering iron because those timers are really sensative to heat. I fried 3 or 4 of them making my last ignition circuit.
K.
Old Jan 23, 2006 | 11:49 AM
  #52
"Beemer Nut"
What does the MotorCraft ignition module look like, size and location on the late 70's to early 80's Fords? I'll go to Pick-N-Pull if I knew what I was looking for. Ford ignition for me is a Crane XR3000 on the 68 CS.
.....=o&o>.....
Old Jan 23, 2006 | 02:46 PM
  #53
liftedf100's Avatar
liftedf100
Flame Thrower
Ebay!if You Want The Kit For About 40 Bucks.thats The Way To Go. I Bought My Fron It And It Shhoots A 3 Foot Flame Everytime.the Only Thing Is You Truck Cant Have A Cat Enless You Put An Injector Taped Into Your Fueline Dont Use Propane Though.no Flames Just Big Bang!
Old Jan 23, 2006 | 04:59 PM
  #54
BIG-BAD-794X4's Avatar
BIG-BAD-794X4
I just have glasspacks and 3''x9'' crome tips.
is that ok? and should i put the plugs in the tips or in the pipe right behind the tips?
Old Jan 23, 2006 | 09:42 PM
  #55
liftedf100's Avatar
liftedf100
my flame thrower
Check Out My Gallery "lifted F100".its A Flat Black 1976 F100 I Have Pics Of The Spark Plug Setup Maybe That Will Help You But I Dont Have Any Pics Of The Flames Yet But I Should Tommarow.
Old Jan 23, 2006 | 09:46 PM
  #56
Purely Ford's Avatar
Purely Ford
This idea is fun for sure, but it increases the risk of removing people from the gene pool or at least being on the news. LOL.
Old Jan 23, 2006 | 09:51 PM
  #57
BIG-BAD-794X4
what kit did you get, and what did you have to do to get flames that big??
Old Jan 24, 2006 | 01:50 PM
  #58
amish77's Avatar
amish77
The bigger flames is just more exhaust pressure and more fuel. If you use the nos nozzles you can set your jetting for more fuel, just make sure that you have enough pressure on the exhaust to blow the flame out the exhaust.
Old Jan 24, 2006 | 01:56 PM
  #59
BIG-BAD-794X4
how much is enouf pressure?
Old Feb 1, 2006 | 04:53 PM
  #60
amish77's Avatar
amish77
just keep the rpm's up. don't worry about the actual numbers on pressure. 3000RPM or better should be fine.
