Electric brake control plug
Old Jan 14, 2006 | 05:47 PM
ejpreston's Avatar
ejpreston
I have a 2004 Regular cab, 4.6 2wd. The truck is pre-wired with a 4-pin connector at the rear bumber. Would it also be wired for the plug-n-play controllers such as the Prodigy? I see a grey plug under the dash, just at the edge of the plastic trim, but how would it be connected to the rear of the vehicle for a 7-pin plug I would have to add? Thanks.
Old Jan 15, 2006 | 12:04 AM
desratt's Avatar
desratt
that plug you are looking at is a onboard diagnostics test plug
Old Jan 15, 2006 | 12:15 AM
ford390gashog's Avatar
ford390gashog
the other harness end is pushed up under the dash it has a large bright blue wiring running to it.
Old Jan 15, 2006 | 12:51 AM
desratt's Avatar
desratt
what's that?
Old Jan 15, 2006 | 12:52 AM
ford390gashog
the blue wire is for the trailer brakes it dead ends into a grey connector with 3 other wires.
Old Jan 15, 2006 | 02:25 PM
ejpreston's Avatar
ejpreston
I see the OBDII plug, but the grey plug is to the left of that. So is that it or do I not have a plug for the electric brake?
Old Jan 15, 2006 | 04:13 PM
ford390gashog
the grey plug is small about 3/4'' wide.
Old Jan 15, 2006 | 04:20 PM
ejpreston's Avatar
ejpreston
Right. So is that in fact the e-brake plug, and if so, where does it end at the rear of the truck for the trailer connection? Thanks.
Old Jan 15, 2006 | 06:52 PM
DearbornDerek's Avatar
DearbornDerek
Rear left frame under the bed just past the last cross piece of the frame. Your four pin should connect to this plug. Replace your four pin with tow package harness( 4 & 7 pin). There is also a ground strap secured by a screw. Since you have an 04 you should be able to get to it. The ground strap on the 05 and up secures on top of the frame under the bed.
Old Jan 15, 2006 | 11:43 PM
ejpreston's Avatar
ejpreston
I'll check it out. Thanks.
Old Jan 16, 2006 | 05:11 PM
simpson117's Avatar
simpson117
I just went through the same situation with my 04'. Brake control plug is under the dash ready to go. Out back there are 2 pieces you need to buy from your dealer. 7 pin connector and wiring loom, plugs in up by the spare tire. I was givin the brake controller plug by a friend but bought the other 2 pieces for $77 from the dealer.
saltbranch
All Things Towing
13
Nov 26, 2013 04:36 PM
wasmblad
All Things Towing
Jul 22, 2013 10:05 PM
Hotairjunkie
May 12, 2013 01:50 PM
bossgobbler
Oct 27, 2011 08:18 PM
fire3110
Nov 11, 2009 12:34 AM
