Weird light problem
Old Jan 14, 2006 | 10:32 AM
JForestZ34's Avatar
JForestZ34
Weird light problem
On my 2006 FX4, when I start the truck in the dark with the drivers side door open, as soon as it fires up, the interior lights fade out as if you just shut the door but the door is still open. Pretty inconvenient when I start my truck in the dark early in the morning and trying to load my work crap into the truck. Have to shut the door then open it again for the interior lights to stay on.
Anyway to change this?
This posted on another forum. This is happening with my truck also. Dose anyone have any ideas.
James
Old Jan 15, 2006 | 11:48 PM
LAAdkins's Avatar
LAAdkins
When you reach in to start your truck why don't you turn on the overhead lights with the dash dimmer control.?
Old Jan 16, 2006 | 03:51 PM
JForestZ34's Avatar
JForestZ34
Lights
I shouldn't have to do that. If the door is open then the lights should stay on....
James
Old Jan 16, 2006 | 03:58 PM
superrangerman2002's Avatar
superrangerman2002
Does your truck have the system display center on the bottom right of the speedo cluster?
If so, whats the auto-dim set to?
Old Jan 17, 2006 | 07:08 AM
JForestZ34's Avatar
JForestZ34
Lights
It has the mini display not the full display
Old Feb 9, 2006 | 03:55 PM
jekin's Avatar
jekin
I have found the same problem on my 05 SCREW BUT on the passeger door will check other door soon my thought was if the front doors were open the lights should stay on my cars all do
Old Feb 9, 2006 | 06:38 PM
96f150's Avatar
96f150
James, I was just thinking about this the other day myself. I have an 06 XLT, and Mine does it to. Just like you, I try to load my maps and gear early in the a.m, and the dang light shuts off. Why doesn't the light stay on? The door IS still open, hence, the light should be on.....Strange system
Rich
Old Feb 9, 2006 | 07:56 PM
Cuisinart's Avatar
Cuisinart
My 05 scab also does this. quite annoying. Wish I knew a fix.
Old Feb 13, 2006 | 08:26 PM
Cuisinart's Avatar
Cuisinart
bump in the hope of fresh input
Old Feb 13, 2006 | 08:39 PM
cullenkyla's Avatar
cullenkyla
Just went and checked mine out 04 screw does the same thing I tryed it both
ways auto headlight on and off same outcome they go off as soon as the truck
starts with door open
Old Feb 18, 2006 | 07:19 PM
Cuisinart's Avatar
Cuisinart
A better question then would be; Does anyone have a truck that does NOT do this?
Old Apr 26, 2006 | 05:42 PM
Cuisinart's Avatar
Cuisinart
Wow, I had hoped that someone had a resolution for this issue by now. Regardless, my question still stands
Also, something strange happened the other morning. I started my truck and the light stayed on. I didn't do anything different and it hasn't done it since, so I'm still mystified by this small problem.
Old Apr 26, 2006 | 08:40 PM
Dazz's Avatar
Dazz
My dome light goes out after whatever times it tells it to go out. I like this as often I will leave a door adjar and the auto light switch possibly saves me a battery recharge. This is perhaps the reason that the dome light goes out, to save battery when it is expected that no dome is needed.
Old Jun 20, 2006 | 08:34 AM
JForestZ34's Avatar
JForestZ34
Light
Still nobody has found a reason why this happenes.
James
Old Jun 20, 2006 | 10:35 AM
KZooDirt's Avatar
KZooDirt
Nope.
(Mine does too)
