Modular V10 (6.8l)
Looking for a stock Y pipe
Old Jan 12, 2006 | 12:34 PM
rlampman's Avatar
rlampman
Post Looking for a stock Y pipe
I am looking for a stock Y pipe that someone has removed. Mine has been modified and I am not liking the higher torque range. It did improve the power but I would take any lower torque for when I tow my trailer with my 3.73 gears.
Anyone have an extra laying around?
Rod
Old Jan 12, 2006 | 05:43 PM
V10man's Avatar
V10man
I have one off a 99 you can have *FREE*if you pay shipping. Only thing wrong with it is an O2 sensor stripped in one of the bungs. The sensor stripped not the bung so it should be easy to fix.
Old Jan 13, 2006 | 12:51 AM
rlampman's Avatar
rlampman
Thumbs up
That sounds great You have a private message..
Thanks
Old Jan 13, 2006 | 04:42 PM
rlampman's Avatar
rlampman
Anyone know the specifics on the Y-pipe for 2000 vs 1999? V10man has a '99 and not sure it is the same. I would like a direct bolt in so I can keep my modified one for now.
Old Jan 13, 2006 | 05:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
Hmmm...don't think they changed between those two year but also am not sure if it is a bolt on. I think (and V10man will verify) that the Y-pipe is welded to the cat.
Old Jan 13, 2006 | 06:24 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I have a free 2000 y-pipe. Figure out how I could get it to ya and it is yours also. I have been holding on to it for nothing.
Old Jan 13, 2006 | 06:34 PM
V10man's Avatar
V10man
Rod, take V10KLZZ71S's pipe. It will fit no problem.
The cat is not welded on on either but the distance from the 3 bolt flange is different. On the 99 the flange is about 4" from the cat while the 00 and newer are about 18" or more.
[IMG][/IMG]
What I think is interesting is the Y it's self. On the 99 it looks to be a smooth transistion, while the newer ones it's more like a T.
Old Jan 13, 2006 | 10:59 PM
rlampman's Avatar
rlampman
I think the 2000 one would be great. That way I can switch back if I want to.
V10KLZZ71S you have a Private Message, Thanks
Old Jan 14, 2006 | 05:00 AM
V10KLZZ71S's Avatar
V10KLZZ71S
The only problem is I used a torch to remove the cat from the y-pipe, but the flange is still on the cat. I can send the flange too. Just need a muffler shop reconnect it to the y-pipe.
Old Jan 14, 2006 | 11:06 AM
rlampman's Avatar
rlampman
That would be fine as long as I can get both parts.
powerstroke8806
Mar 29, 2016 01:09 AM
bigbuck75
Aug 26, 2015 05:56 AM
Giterduun
Aug 8, 2014 03:50 PM
mrad
Jul 19, 2011 02:19 PM
bob1987f
Exhaust Systems
Nov 23, 2007 11:20 AM
