Exhaust back pressure sensor
Old Jan 12, 2006 | 08:41 PM
johnny8's Avatar
johnny8
ok... here's a dumb question... does installing a larger exhaust from the turbo back help to reduce back pressure and possibly make the exhaust backpressure code go away...? i ONLY get that code when i am running very high boost pressure at high rpm.... just wondering...
Old Jan 12, 2006 | 08:53 PM
jtharvey's Avatar
jtharvey
It makes sense that it would reduce the backpressure. Take away the restriction from the exhaust, and I'm sure it helps. But, you've still got the restriction from the turbo though. Good question.
Old Jan 12, 2006 | 08:55 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Possibly. It will reduce the backpressure somewhat, but if it's enough to prevent the code.....???
The easiest way to cure it is to run less fuel....assuming that is not an option , the next most effective way is to install a larger turbine housing. That is assuming that you want to control the actual pressure and not just defeat the SES light.
Old Jan 13, 2006 | 01:16 AM
jtharvey's Avatar
jtharvey
You're right cookie, less fuel is not an option. A turbine housing would be preferred, but $30 to defeat the SES light is a lot easier to swallow than $500 for a housing. A housing is still in the works for me though.
xc4jokestomper
Dec 9, 2011 07:45 AM
triskit16
Oct 27, 2008 09:59 PM
ALdieselfan
Jul 14, 2007 05:50 PM
96ford4x4turbodiesel
19
Jun 20, 2004 01:15 PM
Hiflyer746
May 21, 2004 06:36 AM
