Anyone running the ATS ported shroud?
Originally Posted by Kwikkordead
I don't have it but I've heard that it's a lot noisier than the stock housing. That's some big air though.
Originally Posted by Fire Rooster
Its a good loud!!!
Originally Posted by whitesdford
here comes a dumb question, what is this flutter you speak of in the turbo? I tow heavy all the time, and havent experienced this (at least i dont think). Could you explain this?
I have the WW installed on my truck, I have no flutter issues and I tow a large 5th toyhauler. If I had the money I would go ATS but, since I do not have an issue now I cannot justify the cost.
Flutter, AKA surge, is when under heavy load, between usually 16-20 psi the exhaust side and intake side have a pressure difference thus causing the turbo to spin stop spin stop and it sounds quite choppy and the needle on the boost gauge is all over the place. Bad on turbos.
Here, I found a very technical definition of turbo flutter: "Blade flutter is self-excited blade vibration due to the interaction of aerodynamic and structural dynamic forces. Flutter can be a serious design problem for the manufacturers of turbomachinery as it leads to dramatic blade failure."
Now, I'm sure that doesn't really clear anything up, but it's they type of info that could help some.
Heatstroked is running one. It is much louder and that bleeder, man the first time I heard it thought he hit the skids, it is a loud screeching sound. Sounds bad ***, would love to get one but canot justify the cost just for noise.
If you are considering the ATS for eliminating surge, and you have the money, get it. The housing is a breeze to install and it does sound "bad ***" spooling up and backing off the go pedal.
Now, if you don't have the cash and you like to wrench, then get the WW for your surge issues. You'll still have some whistling.
