Caster adjustment
Old Oct 4, 2001 | 01:08 PM
beartracks's Avatar
beartracks
Caster adjustment
After replacing "EVERYTHING" in my suspension life is good except for one little nagging problem. I have a slight pull to the left that is worse with speed and a little bump steer, always to the left. I just had it aligned to 0 toe in and 1/4" pos. camber but they didn't record the caster values. Problem appeared after I changed everything and was there before and after alignment. What if I add an 1/8" space to the right strut to increase caster on that side? Any other ideas would be appreciated.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Oct 6, 2001 | 10:12 AM
dinosaurfan's Avatar
dinosaurfan
Caster adjustment
Bear, if you mean you want to add a 1/8 th spacer under the rear of the radius arm, yeah that may help. But will it be enough ? I measured the radius arms @ 23 inches on my truck. If we look a the cicumference of a 46 inch circle, and divide by 360 degrees, we need about .40 just for one more degree of caster. The factory gives about 3 or 4 degrees and I would like 12. There might be more to be gained at the front of the arm. If anyone else has a good idea lets have it. DF
Old Oct 8, 2001 | 10:10 AM
Mikeyou812's Avatar
Mikeyou812
Caster adjustment
When you discover what your problem is, please let me know. I have a 1969 Ford F-100 which at 60 MPH the pull to the right is some times more than my powersteering can handle. I have changed everything but the shems, guess they are next.
Old Oct 8, 2001 | 11:57 AM
beartracks's Avatar
beartracks
Caster adjustment
It would really be good to know exactly what the caster is in order to have a benchmark but I don't know mine. I added an extra cup wash on the radius arm in from of the bushing where it mounts to the frame. This should have pushed the right side wheel forward 3/16". It seems to be a bit better but I may need another washer in there. I know the track front to rear is 3/4" longer on the left side. (before I added the washer) It may be a week or two before I can get back to it but will update the post after the next washer. I also need to make sure the nut on the left side radius arm is as tight as it will go. Just thought of that one.
1977 Ford F-100
280,000 miles
Old Oct 8, 2001 | 06:54 PM
DaffyDuck's Avatar
DaffyDuck
Caster adjustment
FIXIT1
Sep 10, 2013 09:45 PM
shuttlevalve
Aug 18, 2008 10:55 AM
okiebronco
Feb 6, 2003 10:31 AM
beartracks
Sep 19, 2001 09:27 PM
