1978 - 1996 Big Bronco
Rear Gate Window Malfunction Fix
Old Jan 9, 2006 | 02:09 PM
RanchRodsTX's Avatar
RanchRodsTX
Saturday, my rear gate window started acting weird, slow, fast updown motion and then didn't work at all. Down but no up??????
I spent yesterday looking for a fix. After tearing the motor out and lubing the mechanism, I decided to check the latch interlock. The plug was corroded so I cleaned it with some Rubbing Alcohol used some dielectric grease and it works fine! Guess I got a new maintenance item.
Old Jan 9, 2006 | 06:43 PM
Streetgang's Avatar
Streetgang
I am 99% sure that the problem is the "torque pins" inside the window motor. Its a very common problem......you will hear the motor running and the glass may bump around a bit but dont go up. Here is a pic of the gear.......BTW its a VERY easy fix!
Also click on this link for a ton of good tailgate info!
http://www.supermotors.org/vehicles/registry/detail.php?id=2742&s=12689#content
Old Jan 10, 2006 | 09:56 AM
RanchRodsTX
I did that while I had it tore down just because it was a good time to do it. My pins weren't that bad and the gear was solid so I was probably okay. The latch switch plug was the real problem.
Old Jan 10, 2006 | 05:48 PM
Streetgang's Avatar
Streetgang
So then I am assuming you have fixed it??? If not what many people here do is just jump the safety switch out of the system. The safety switch is also a very common cause for the failure of the rear window to work correctly.
Old Jan 11, 2006 | 03:41 AM
muckypaws's Avatar
muckypaws
M8 nuts are a good replacement for the torque pins if you're really stuck!
ford1977owner
Apr 16, 2012 04:06 PM
RJH123
Oct 27, 2009 09:32 AM
Backhus
Jan 15, 2004 10:01 AM
devilstrip
Dec 31, 2003 12:18 PM
nixvet
Nov 25, 2002 12:47 AM
